Thread: Ok Newbie with my TF-100
    Jan 2015
    Puyallup, WA
    50
    Ok so we put up the pool for the first time and have added nothing as of now. PH is 7.5 but my CYA is 0 but than again I haven't added anything as of now. So this tells me that I need stabalizer correct. If so what do I buy for stabalizer?
    Thanks
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    Re: Ok Newbie with my TF-100
    What does what and how to add it is all covered in Recommended Pool Chemicals.
    Jan 2015
    Puyallup, WA
    50
    Since my cya is 0 and my fc is 0 can I add both the stabilizer and bleach in at the same time?
    Thanks
    Richard320's Avatar
    Jan 2010
    19,073
    Quote Originally Posted by octanefam View Post
    Thanks
    Yes, because CYA dissolves so slowly. Normally you wait 30 minutes between doses. Be sure to follow the instructions in Recommended Pool Chemicals on how to add, and aim low with the CYA. You might have some in there but it's too low to read. You don;t want to go too high. Adding more is easy. Removing too much is not.
    Jan 2015
    Puyallup, WA
    50
    Ok I added my stabilizer last night and then added my bleach about an hour afterwards. Pump has been running since last night. This morning checked the sock and gave it a squeeze.
    As I have read here it's ok to swim with just adding these two components. I know my son will want to swim today it's not very often we get 80 degree weather in May in the Pacific Northwest The pool is a bit chilly still, yesterday it was at 65 degrees but it didn't stop either of us.
    Thanks for all the help.
