Thread: Direction of Solar Pool Panels
    May 2015
    ny
    2
    Hello, I just bought 2 4x8 solar pool panels. Is it ok to install the solar pool panels vertical instead of horizontal?
    Headers to the right and left, inlet at right bottom of roof, outlet at top opposite side(left).
    Thanks James
    Apr 2015
    Brookline
    60
    Re: Direction of Solar Pool Panels
    Exactly what I have, vertical. Inlet on bottom left, out from top right
    Southern New Hampshire, 18x36 single roman end pool.
    May 2015
    ny
    2
    Thank you, so there is no problem with it heating for you? How are you bracing the panels? I like the set up because it's an easy 8x8 panel.
