Results 1 to 10 of 10
Thread: Any reason why I should avoid Redmax bleach?
    critterdoc's Avatar
    Oct 2008
    30.0217 -090.2403
    23
    182 oz RedMac 6.0% is one buck less expensive than 182 oz Clorox 6.15% at our local Lowes. I cannot find 12% anywhere in this backwater town [the greater New Orleans area] so I guess 6% will have to do. The appearance of the two products differs in that RedMax has a mildly greener cast compared to Clorox. Over time the saving might be worthwhile but not at the risk of RedMax being an inferior product. What say you BBB gurus about RedMax as a sanitizer?
    20K gal gunite, plaster in poor condition post Katrina
    1.0 or 1.5 hp primary pump
    Polaris 280 and Polaris pump
    Her name is: Free To Good Home :wave:
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Any reason why I should avoid Redmax bleach?
    The party line is that ant unscented bleach that's not a gel is ok to use in the pool. Just be sure to check the ingredients for anything not sodium hypochlorite or water.
    Given the current economy, saving $1 whenever you can is a good thing 8)
    Luv& Luk
    -Ted
    critterdoc's Avatar
    Oct 2008
    30.0217 -090.2403
    23
    Quote Originally Posted by waste
    I was unable to find anything specific on the 94% "other" ingredients in KIK International's RedMax online. As matter of fact I was not able to find much of anything on RedMax online except for an english MSDS [http://tinyurl.com/5lbw53] for KIK International's "Germicidal Ultra Bleach" which only describes the Hazardous Ingredient named as Sodium Hypochlorite and the New Jersey Pesticide Control Program [http://tinyurl.com/5tulyn] reference sheet that also only specifies the Active Ingredient of Sodium Hypochlorite.
    It has not occurred to me that RedMax smells scented, but I'm not sure what scented bleach smells like any way and I'm not sure I want to go off the wire running sniff test of various bleaches.
    Mar 2007
    4,160
    If it doesn't say scented, then it's unscented - the 6% is a good indication that it doesn't have the scenting ingredients.
    Sounds like it's just regular bleach that costs less - go for it
    Luv& Luk
    -Ted
    30,419
    Doc,
    I've had good luck finding 12% bleach at a specialty store that supplies pressure washing businesses. It's not really cheaper (by much) but it's a little more convenient. Depending on location, it might be for you, as well.
    Meanwhile, Any brand of bleach that contains just chlorine and water is fine.
    I may be late to this thread but I'll chime in anyway. Any product manufactured by KIK is good. They all come off the same lines and their quality is the best in the industry. All that should vary is the concentration.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    Our Leows carries Redmax. I used many bottles of that and Target brand bleach for shocking this fall. They seemed identical except the Redmax is a little more expensive (in my one horse town anyways) and the Redmax was a little "yellower" in color. I use the Target bleach when I can get it, the Redmax when I have to get some right away and cannot go the Target (45 min away).
    28 ft round Doughboy Sand Dollar II AGP, Aug 2008: 4 ft shallow, 6ft deep end: 24K gal approx Hayward Power-Flo Matrix
    1&1/2-HP 2-SPD Pump, Hayward 27-Inch Sand Filter with a little DE -(2) 4ftx20ft Solar Bear AGP Panels w/ Goldline auto-controller, 50ppm Borates And some day, maybe this year, a DECK!!!
    I've been using RedMax as well (from Lowe's). It's worked successfully for me so far. What are you paying there? Here you have to buy it in packs (boxes actually) of two 182 oz jugs.
    24,000 G, Sand, IG, Vinyl
    Apr 2012
    Sioux City, IA
    11
    Found a pdf from Minnesota well shocking web site listing at 6% on page 6 of the pdf the bottle says the manufacturer is Hi-Lex
    Attached Files Attached Files
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by Cabinetman
    Thanks for pointing me to that site, cabinetman! I am from MN and didn't even know that site existed It has some great info for shocking wells that I have not been able to find in one place before...and sanctioned by a governing authority.
    For anyone else interested here is the url: http://www.health.state.mn.us/divs/e...tion.html#when
