Thread: Hayward pump leaking
    May 2015
    Valley Forge PA
    2
    I have a 1hp Hayward super pump and the rear seal is leaking. I went to my local Leslies store, where I bought the pump 5 years ago, and got a new rear seal and a gasket kit. Replacing the seal was pretty simple, but it still leaks. I sanded any rust off the shaft before I installed the new seal and used gloves to handle the parts. I did not use any type of lubricant or sealer on the new seals. Is there something I am missing?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Hayward pump leaking
    All I can think of is that the seal was installed backwards. Seals are usually designed so the pressure against them forces them tighter against the shaft.
    May 2015
    Valley Forge PA
    2
    OK, took the pump apart again this morning and after looking over the new seals very closely, I found that the carbon seal on the spring was split. Took it back to Leslies and got a new one. No more leaking I'm glad to have a Leslie's store so close by with a great tech.
