Results 1 to 7 of 7
Thread: saltwater system quesiton
    May 2015
    Woodsboro
    2
    Control center of the saltwater system went up am waiting for a new system to arrive-until then what should I do with the pool to keep the water in good quality? I can use the filter pump but no chlorine is being made or cyn! Is there something I should use just to keep the water clean until chlorine is being made again?
    We have an intex pool that is 18' x 9' x 52". It is about 3 years old and this is the first year we had to patch a few holes in the bottom. We use a saltwater system with a filtering pump all in one, that is about 3 years old as well.
    Overall we have been very happy with our set up.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: saltwater system quesiton
    If your SWG is not working, manually chlorinate with bleach.
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Use pool math to calculate how much bleach to add every day to keep your chlorine level above the minimum for you CYA level. Pool School - Chlorine / CYA Chart
    May 2015
    Woodsboro
    2
    It is okay to add regular laundry bleach to pool water? If I go to the Pool School option I will find a Chlorine/CYA chart?
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    yes. use regular laundry bleach. Do not use splash-less or scented.
    May 2014
    Franklin, NC
    9,184
    Pooldv put a link to the chart in his post and yes, plain laundry bleach. No EZ pour, no scents, no flavors. Pool Math will calculate Ho much you need to add.
    Support the site
    DFW, TX
    24,483
    I buy store brand plain old unscented bleach at the grocery store, 8.25%
    p.s. blue text is an active hyper link that you can click.
    Like this --->> Pool School - Chlorine / CYA Chart
