Thread: Ok to leave the system in AUTO when there is no flow?
    Jul 2012
    Austin, TX
    75
    Hi all,
    I have a Hayward salt water chlorine system. My pump has an internal timer, so it does not use the external timer and it is always on. The salt system connects to the same load, so it is also always on. My pump does not run at night. Is it a problem for the salt system to stay in AUTO when there is no flow?
    Scott
    Lazy-L shaped pool and a spa. 22.5k gallons. Pentair VS pump. Pentair cartridge filter CCP520. STA-Rite SR400NA heater (400K BTU). Leuder limestone coping. Pebble sheen (blue granite) Wooden deck.
    Re: Ok to leave the system in AUTO when there is no flow?
    In the short run that is fine. But you shouldn't leave it that way long term. If the flow sensor in the SWG ever fails, and they do tend to fail eventually, there could be an explosion hazard. It is always best to have something additional that shuts down the SWG when the pump is not running.
    One way to do that is to get a current controlled relay to turn the SWG off when the main pump is not running. Another approach is to get a separate timer that turns the SWG off, though if you do that you need to take care that the two timers remain in sync.
