Results 1 to 9 of 9
Thread: Cool pool
    May 2015
    Houston TX
    49
    Cool pool
    We are building a pool ( our 1st ) in Houston. I am concerned about the water temp being too hot in late summer. I asked my pb about a chiller. He discouraged me from going that route. We will have 3 waterfalls and 2 jets and a bubbler on the tanning shelf. Will this help with the water temp or should we go with the chiller ? Should we install 4 jets instead of 2 ? I appreciate all your help. This forum has already taught me a lot !
    Houston,TX, IG 15120 gal, gunite, 22' x 36',wet edge finish, Pentair equip, 420 cartridge filter, vs pump, Intelliflo vs booster pump for water features, 400,000 heater, auto fill ,PCC 2000 in floor cleaning ,2 LED lights,travertine coping, paver decking, 9x12 tanning shelf ,1 LED color bubbler, 2 5' benches w jets. Depth 4- 4 1/2- 5 , wall with 3 24" sheer decent , 2 spray heads, Intellitouch Controller.
    38,370
    Re: Cool pool
    Any aeration will lower the water temp (and raise the pH).
    One option would be adding solar panels. You could run them in the spring and fall to add heat to extend your season and then in the summer run them at night to cool the pool.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Cool pool
    Don't cross that bridge until you come to it. With your features it may never be a problem. Plan for it if you want, but don't go crazy on that just yet.
    Essential Links:
    May 2015
    Houston TX
    49
    Re: Cool pool
    Thanks Patrick ! I guess I've got too much time on my hands, lol ! Just waiting for our dig ��
    As expected, our pb is a little backed up due to the rain !
    One more question, will 2x4 stacked stone on our pool wall be a problem to clean or should we go with tile ?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Cool pool
    Reverse operation solar panel cooling does work in our climate, but is limited due to the tendency to have high humidity and high temperatures at night in the summer on the gulf coast. (Jason it is not uncommon to have lows in the upper 80's at 3 am in August with near 100% humidity to block radiational cooling).
    Ike
    38,370
    Re: Cool pool
    Got ya ... but what is this humidity of which you speak?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Cool pool
    It is the stuff that makes bread soggy when you leave it out and keeps it from turning crunchy
    38,370
    Re: Cool pool
    Interesting ... I like setting my bread out for a few minutes and having it get crusty like I toasted it
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: Cool pool
    I live in south Louisiana and it gets really hot. We use a pool fountain at night and easily reduce the temp 8-10 degrees. I point it so that it shoots as high as possible and it works great. Check it out below. If you used two you would probably see even better results.
    Amazon.com: pool flower fountain
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
