Thread: Sight Glass Leaking
    Aug 2014
    Shickshinny/PA
    9
    Sight Glass Leaking
    Please help! My husband opened our pool and I noticed that the sight glass is leaking when I'm trying to backwash. It has no water in it during normal filter mode. He said that he installed everything the exact way that it was last year, but something is definitely wrong. We have a Triton Sand Dollar filter with a hayward pump.
    Thanks!!!
    38,271
    Re: Sight Glass Leaking
    There should only be water in it when you are backwashing ... so it does not matter if it is empty in filter mode (that is normal).
    Also, I would not let a little leaking bother me since it will only happen while you are backwashing.
    May 2013
    Long Island NY
    419
    Mine leaked a little and I just unscrewed the glass jar and put a few wraps of Teflon tape on it and it stopped the leak.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    I have some slight leaking near the backwash sight glass. It's been that way for a couple of years. Wouldn't sweat it. One tip I can give you is, look for a drain plug on the backwash pipe. If you have one, lubricate it with a spray lube or a drop or two of oil and give it a twist. In winter, make sure that all water is drained from the backwash pipe to prevent freezing. The small leak I have was likely caused by freezing water in the backwash pipe before I became educated about pool management.
    There should be a rubber washer in the threaded hole. You can use a regular hose washer. The larger flat red washers fit best.
    Support the site
