Results 1 to 9 of 9
Thread: What Type of Light Bulb Is Needed?
    Mar 2015
    Largo, FL
    94
    I need to change the bulb in my pool light. However, I'm having trouble determining what one to purchase. First off, do I really need a $200-$400+ "pool light" bulb? Or could I use one of the substantially cheaper wet-rated LED flood / recessed lights? The fixture seems to have the standard edison style, so any normal bulb would fit, and LEDs are wet-rated and should run cool enough to survive in the enclosure I think. Additionally, how can I tell if I have a 12v or 120v socket? The fixture is so old that all the labeling has worn off, and the bulb exploded in my hands while I was messing with it, so there's nothing readable there. Is there anything else I need to be aware of?
    15k gallon (?) kidney-shaped inground concrete (paint) pool & spa combo undergoing resurfacing. 6 floor jets, 2 side returns around steps, 1 skimmer also near steps. Spa has 4 jets. 1 hp Sta-Rite Supermax, 1.5 piping, Pentair CC100 cartridge filter (holds up to CC200), ComfortZone gas heater - old and broken, Master Pool return distributor (not sure what to call it). Pool Before Resurface
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: What Type of Light Bulb Is Needed?
    typically if its 12 volt you would see somewhere a transformer box that converts it from 120v, do you have such a transformer?
    I was thinking about replacing my light with an LED and there seems to be several on amazon that are 12 and 120 volt but you
    need to know for sure which one you have first.
    Dolphin E10 Cleaning Robot.
    Mar 2015
    Largo, FL
    94
    I'm new to this, and homeownership in general. I honestly don't know what a transformer looks like. There is a metal box the wires run through shortly after leaving the circuit breaker. I assume this may be one, but I don't know how to confirm.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Look on the base of the lamp you took out. It should have voltage and wattage stamped on it.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Mar 2015
    Largo, FL
    94
    Quote Originally Posted by n240sxguy View Post
    There is nothing stamped on the metal itself. That information was on stickers that have become unreadable due to moisture. I could make out the words watts and model but nothing else, so they are of no use.
    If I were to put in a generic household lightbulb (out of the water of course), what would happen if the voltage is wrong? My thinking is that if it's a 120v line and I put in a generic household bulb it will either go out quickly or at worst explode. If it's 12v then the bulb should work pretty normally. That could tell me the voltage so I can go get the right kind of bulb. Does this test make sense? Is there any damage that could be caused to something other than the bulb?
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    As long as you keep it away from the water, use a tester to verify the voltage. If there's not some little plastic or metal box that doesn't look like it goes to anything, I'm guessing it's 120v. If you test it with a regular 120v bulb, it should light up normally at 120v and may not light up at all on 12v. It shouldn't hurt the bulb, but it may mess up the transformer/power supply if you have one. I doubt it would hurt anything, but still better to use a meter so it isn't actually drawing current.
    Mar 2015
    Largo, FL
    94
    Well that was a head-slapper! I totally forgot I even had a voltmeter! I don't think I've used it since wiring up my car stereo about 8 years ago.
    So I have a 12 volt current. Does that mean that I can use almost any LED bulb? Or am I still stuck with the ones that cost a couple hundred dollars?
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    I don't see why you couldn't use any led bulb. Not sure what the difference is between them and the pool bulbs besides price. I assume the pool ones are oriented like a floodlight or spotlight so that style is what I would use.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    A year ago I swapped out my 300watt incandescent Edison bulb for a BulbWizards PoolBright 202 LED Color Changing Replacement Bulb (see my review here).
    At the time it was about half the price of the competitor's bulb, so I figured it was worth a try. I haven't seen anyone else here with this bulb, but I love mine.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
