Thread: Installing a Heater
    May 2015
    Albany, NY
    2
    Question Installing a Heater
    I have an equipment/installation question. I purchased a Sta-Rite Max-E-Therm Pool Heater. It is plumbed for a 2 inch intake - however my filter and outflows are 1-1/2 inch PVC. Can I go from 1-1/2 to 2 inch at the heater intake? Will the heater receive enough water pressure to run????
    In Ground 16 x 32 lined pool. Haywood EC75 DE filter, 1 1/2 HP Haywood Super pump. Sta-Rite 333 Max-E-Therm Pool Heater.
    Re: Installing a Heater
    Welcome to TFP!
    Using adapters to change the pipe size near the heater is totally fine.
    May 2015
    Albany, NY
    2
    Thanks JasonLion,
    Another question: The Sta-Rite 333 Max-E-Therm Pool Heater comes set to 220 by default. There is an exchange 8 pin module (included) to switch to 110. Question is there is no up/down on the module. It goes in either way. No mention of orientation in the installer manual. Does it matter - don't want to blow the controller.
    ps0303's Avatar
    Jul 2011
    FL
    3,681
    It is keyed in that it should only fit one way.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Oct 2010
    SWF - Fort Meyers
    47
    Does any one know of the RHEEM heater/chiller Model D6350 TIEHC. I can't find any information about it.
    Roman Style IG 14X28, Gunite Pool and Screen Cage
    11600 gallons, 3.5 ft - 6.0 ft SWG TF100 Kit:)
    Spa with spill over, tanning ledge, swim bench
    Finish TBD, along with equipment and paver's
    Water trucked in were on well system in Florida:)
    ps0303's Avatar
    Jul 2011
    FL
    3,681
    Quote Originally Posted by Happy1 View Post
    Please start a new thread for this question.
    Paul
