Results 1 to 7 of 7
Thread: Help! Added flocc and it's not working
    Jun 2014
    lawrenceville GA
    8
    Exclamation Help! Added flocc and it's not working
    I am a new pool owner. Ive been having a problem with my pool being cloudy. So about 2days ago I added a floc called sink and sweep. I added the whole bottle, which was probably not the best idea but I was desperate. I checked the pool pH which was really low and I also noticed the pool Turing green. I started with a blue cloudy pool. I know I can not turn the filter on with this stuff in my pool or it will clog . my question is how do I get this stuff out of the pool So that I can run the filter again?
    Sand filter,in ground, 18,000
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Help! Added flocc and it's not working
    Hi brown, Welcome to TFP!
    Your root cause is lack of Chlorine in the pool. That's why you've gotten cloudy, and green. If the floc is suspended, and not falling to the bottom, hopefully some will fall, and be able to be filtered out....impossible for me to say.
    You say pH is low, so how low is it, and what kind of test kit do you have? If you have or acquire one that you'll need, we can help you clear the Algae problem with what we call a SLAM procedure. It's a controlled, sustained shock process but it requires a specific type of high level Chlorine test. Post back, and let us know about what you have, and we can go from there. Enjoy your time on the forum.
    Essential Links:
    Jun 2014
    lawrenceville GA
    8
    Hey thanks for replying the pH is 6.8 and cl 5.0. I believe it is a aqua chem kit. If I use the filter to clear clear the pool will it clog the filter.KIMG0158.jpg
    Jun 2014
    lawrenceville GA
    8
    is the pump off now, so the stuff can sink to the bottom? If not, reread the instructions on the bottle. If the pump is still running, get some chlorine in there (best to use liquid chlorine, aka bleach) to the level defined by your CYA level and the Chlorine/CYA chart, let it circulate for 30 minutes, then turn off your pump as described in the instructions for your flocculant.
    While the pump is off, take the time to read Pool School, using the table of contents on the left to go through all the articles. You will learn how to take control of your pool, and you'll never need flocculant again! And your pool will cost dramatically less to maintain. Cool stuff.
    After the stuff has sunk to the bottom (and you've studied Pool School ), vacuum to waste.
    25000-gallon semi-public IG concrete/plaster pool, Triton II sand filter
    750-gallon semi-public IG concrete/plaster spa, cartridge filter
    Volunteer pool caretaker for my condominium complex
    Jun 2014
    15,189
    "brown", you can remedy your problems first buy obtaining a good test kit (TF-100 shown below in my link). That is the foundation of everything you need to do. As others have stated, review the links below designed to help all pool owners (Pool School, ABCs of Water Chemistry, Chlorine/CYA chart, etc). If you are going to the pool store for testing or advise, you will always be disappointed, and probably find yourself broke $$. Start buying some "regular" bleach at one of your local stores, since that is your best defense against cloudy water and/or algae.
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    @TomBorg, i would suspect brown doesnt know what a CYA level is, much less what the number is. as Texas Splash said, a good test kit is a must. brown, if you need a cheap test quickly that will test your CYA, this test has enough to do 2 tests: http://www.walmart.com/ip/HTH-6-Way-Test-Kit/17043668
    but the TF-100 should be ordered ASAP
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
