Thread: how many amp service to inground pool
    May 2015
    lindenhurst ny
    8
    I was just wonder what size service ,amps and wire size is usually run to it .heres a list of what will be running on the pool
    variable speed return pump
    4-led lights
    plug in pooL cleaner
    i would like to run the wire large enough for a heat pump for the future incase i go that route .,may even run a cat-5 also
    Aug 2014
    Shallotte, NC
    693
    Re: how many amp service to inground pool
    You need to choose your equipment, first, and post the amp draw of each. (You need to add your pool info to your sig.) But, you'll really need 230V.
    Cat-5 is a different animal in a different conduit.
    Dec 2009
    Central Massachusetts
    2,690
    With a heat pump, you'll want 100 amp service. It'll be a bit higher than you need, but 60 amp is pushing the lower limits of what you'd want.
    For 100 amp service, you need #3 copper or #1 aluminum.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    38,290
    Quote Originally Posted by bk406 View Post
    How can you say that without knowing the run length? That may be the minimum, but if the run is long, the wire may need to be larger.
    Dec 2009
    2,690
    Voltage drop issues arent as big a problem on something like this as most people think. Actually the minimum for 100 amp service is #4 copper or #2 Alum.
    But, anything over about 5% drop should be upsized.
    For #3 copper at 500 feet under a continuous 60 amp draw (which the OP would never see even with a heat pump running), is less than a 5% drop. For #1 aluminum at 500 feet on a 60 amp continuous draw, its about 5%. Unless he's running the line down to the next block, its fine.
