Thread: Aquarite Fixed! Thanks TFP
    May 2015
    Garnet Valley/PA
    5
    So after opening the pool this spring using the methods all described here my pool water went from green to crystal in 3 days. Completeled my SLAM and let everything slide down into equilibrium. Then I noticed my SWG was not working (lights would come on for 15 seconds then turn off). After a quick note to TFP was directed to a thread "Aquarite not generating - lights not on" and sure enough I had the same issue. Yesterday I had received my current limiter and all my soldering equipment ready and performed the extraction of the old limiter (which looked fine until you touched it then it fell apart) and soldered in the new one. VOILA system works perfectly once again. Just wanted to send a quick Thank You and hopefully inform anyone who is having similar issues. Was an easy, fun and cheap fix (although it's a good thing I don't have to solder for a living!).
    Saved me hundreds of dollars and the satisfaction of fixing it myself. Just signed up to be a site supporter! Next onto adding Borates to the pool.
    Joe
    14,000 gallons IG Carlton ecoFINISH, Hayward Swimpure Plus Salt Chlorinator T-Cell-15-SWP, Hayward DE Filter, Hayward Super Pump 1.5HP, Raypak RP 2100 Heater, Dolphin cleaning robot, TF-100 Test Kit with speed stir
    Jun 2014
    15,103
    Re: Aquarite Fixed! Thanks TFP
    Joe, glad to hear your issue was resolved. Very sorry for the delay in responding to your post. Enjoy your weekend!
