Results 1 to 8 of 8
Thread: about to pull the trigger ,steel or concrete walls ?
    May 2015
    lindenhurst ny
    8
    I found 2 pool companys i feel comfortable with now ,one does the walls in steel the other in concrete, price is almost the same either way.which would you go with and y .im leaning towards the concrete
    May 2015
    lindenhurst ny
    8
    Re: about to pull the trigger ,steel or concrete walls ?
    Anyone have any thought on it
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    hmm, not sure.... the steal sounds like prefab and the concrete sounds formed onsite? if the same price, probably the onsite concrete...
    to make an informed post we would need more information..
    size
    type
    liner?
    soil
    need some more info
    jojoman's Avatar
    Jun 2014
    Mandeville,La
    185
    I would like the concrete mosty because of corrosion issues. I know steel can be treated to where it will not rust in many years and may last the life of the pool but concrete will remain until you tear it out. Just my 2 cents,lol.
    12K gal, custom flipped kidney bean with spillover spa. All Pentair equipment, Whisperflo 1 1/2 HP, 400K BTU heater, Intellichlor IC 40 SWG, CCP-320 Cartridge filters, Kreepy Krauly pool cleaner with bootster pump, QuartzScapes in Aruba Sky blue, LED lights and travertine tiles for decking and stones on rear edge for landscaping. TF-100 test kit w/ SpeedStir
    Jul 2014
    Independence, KY
    234
    (Assuming this is a vinyl lined pool). My initial thought is to go with steel, as concrete always worries me with settling and cracking. Other than potential long term corrosion, what are the other downsides of steel?
    IG W/Vinyl Liner Oval 18x40, 21K gal, Oval 3'-8'
    Pentair Intelliflo VS Pump, Sand Filter
    May 2015
    lindenhurst ny
    8
    Yes its a vinyl liner pool with vermiculite /concrete bottom (not sure what that is is it vermicultie or poured concrete? )pools gonna be a a roman endend rectangke 40x18 .
    Soil is mostly sand i woukd guess since im in long island ,ny
    Jul 2014
    Independence, KY
    234
    The bottom will be a blend of vermiculite and portland cement rather than a poured concrete bottom. You end up with a base that feels solid, has a smooth finish, and is flexible, so that it does not crack or settle like a poured concrete driveway would.
    Nov 2011
    Moberly,MO
    1,010
    Go with polymer over steel. Steel will rust, polymer is forever
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
