Results 1 to 7 of 7
Thread: VS pump without electronic display?
    May 2015
    Novi MI
    61
    I figure electronics with water is never a good thing and has a much more likely to fail than just a simple switch. Is there a good VS pump that uses switches to change the speed instead of electronics? If not then is it better to get a 2 speed? Am I being too cynical? I want something that will last a very long time and not have to replace electronics every 5 yrs. or so. Please make recommendations. I currently have a Hayward super pump 1.5HP (1 1/2" pipes) and the motor has ceased so I have to either replace the motor but want a more energy efficient one that has at least 2 speeds. If I can just replace the motor and it's not too difficult that is an option too. But please tell me the replacement model number I need. I'm new to pools. Thank you.
    26,700 gal (rectangular 18" x 36', CES 3'10" x 4'), IG, Vinyl, Hayward Super pump 1.5HP, sand filter-Hayward S244T, built roughly 5yrs ago I think, 1 1/2" pipe, TF-100, Well and city water available.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: VS pump without electronic display?
    The 1.5 HP Hayward Superpump usually has an AO Smith UST1152 motor, I am not sure the 2 speed equivalent model.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Quote Originally Posted by sxch12 View Post
    No, they all require electronic components. A two-speed is probably your best bet. The two speed version of your motor is the STS1102.
    Mark
    May 2015
    Novi MI
    61
    If I get the STS1102 motor is there any other parts or tools I need to install it? Is it hard? Also is that better than getting something like a pentair superflo VS 1.5HP pump instead of replacing the motor? This is the opportunity to either replace or fix. Thank you
    mas985's Avatar
    Pleasanton, CA
    11,741
    You would just want to get a go-kit to replace the seals and gaskets. Difficulty depends on your skill set so it would be hard for me to say. Here are some videos that will show you what to do. Watch | WETHEAD Pump Repair Supply
    Replacing the motor will cost a lot less than a new VS pump but if you get a rebate for the VS, that can be a better deal.
    Mark
    May 2015
    Novi MI
    61
    I GOT IT WORKING!! I turned the impeller and it loosened up and started to turn. Put it back together and now it works! Thank you
    mas985's Avatar
    Pleasanton, CA
    11,741
    The bearings are probably rusted and the motor might fail soon so I would start your planning now.
    Mark
