Results 1 to 9 of 9
Thread: Replace Wood Deck with Concrete
    Z7What's Avatar
    Mar 2015
    New Orleans Area
    141
    In my back yard I have roughly a 400sqft ground level wooden deck. My son is 1 and is now walking and im worried about him getting splinters. I originally had plans to use the deck over stuff, after reading the reviews on it I decided against it. My next plan was to replace all the boards and stain it but when talking to a friend he said why don't you just rip it up and pour a slab. Well I didn't like that idea because I like having a color stained deck and didn't want some white concrete. While talking to a guy at work he mentioned a stuff called Kool Deck. Has anyone used this stuff or know of a better alternative?
    This is the deck after restained it a few years back. Whatcha think?
    Wayne
    24'X54" Round 15,000 Gallon Pool
    Pentair SD-60 Sand Filter With 1.5HP Pump & Center Floor Drain
    Lil' Shark Vacuum With Leaf Canister
    New TFPC User And Couldn't Be Happier
    Pool School + Test Kit + Pool Math = A Perfect Trouble Free Pool
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Replace Wood Deck with Concrete
    I never had any issues with either child and our wooden deck. As long as you maintain it, it shouldn't be an issue. I'd hate for you to throw money away when the deck looks as smooth as yours does.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Z7What's Avatar
    Mar 2015
    New Orleans Area
    141
    Well that picture was a few years back and it has gotten a little worse since then. I like the fact of the concrete due to not having to restain it once or twice a year which I have neglected the last 2 years or so.
    Wayne
    PoolESQ's Avatar
    Dec 2007
    Albuquerque, NM
    191
    I'm not a fan of the Kool Deck because they do require a reapplication every few years, when the surface starts to wear off. Have you looked into stained/stamped/sealed concrete? Pavers?
    Replastered 2015: Sunstone Quartz Midnight Blue 16x32 rectangular gunite with in-pool spa....18,000 gallons. Autopilot Total Control System with SWG and acid pump. Pentair Clean & Clear 420. Auto cover. TF-100.
    Jun 2011
    Carlsbad, NM
    171
    Dyed and stamped concrete is the way to go. The options are endless.
    36' x 18' 20k in ground, Finest Finish grey plaster, Pentair Tagelus 100D sand filter, Hayward Northstar 2hp pump, Jandy LRZ125EN heater, spill over spa, iaqualink controlled automation, Stenner chlorination, natural rock and flagstone coping, 1" glass mosaic waterline tile, SR Smith Vortex slide.
    Skitch's Avatar
    May 2015
    Athens, Georgia
    111
    Have you considered Trex decking? Remove the deck boards and replace them with Trex.
    If you choose to replace with concrete, where is your stormwater going to drain? Matter of fact, where does it drain now?
    18,400 gallon 28' round above ground pool sand filter 2013 K-2006 2014 new Hayward pump 2018
    My pool turned green the second year, K-2006 saved me, Trouble Free Pool set me free
    Z7What's Avatar
    Mar 2015
    New Orleans Area
    141
    I have not considered anything honestly. I was against the idea of concrete all together up until this morning. Obviously cost will be a factor. If me redoing the boards will cost $750 and stained cement 3K I will just redo the boards. I didn't even think of stained concrete I'll have to look into that price also.
    As for storm water. Just behind my back fence is the woods as you can see. Between the fence and tree line there is a ditch that takes care of the water.
    I don't have a clue what anything will cost other than replacing boards. The section infront the shop is 12x12, the section on the side is 12x14 and then you have the triangle shaped piece where it meets the corner of the house that I'm guessing is 25-30sqft.
    Wayne
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Also not a fan of spray on concrete deck products. The concrete deck on our pool is a rock salt finish with color hardener added, lots of color choices. Completely maintenance free and still great after 3 years. Pics in my build thread in my sig.
    Jul 2014
    New England - MA
    310
    Good move passing on the deck over stuff. I used it on my deck last summer - biggest mistake and waste of time ever. Ended up replacing all the deck boards this spring.
    2015 Pool Build --> HERE IG 19'x47' w/ 7'x7' in pool spa; 3'6"-8' deep.
    Pentair 520 Filter, IntelliFlow VS XF Pump, IntelliChlor IC60 SWG, IntelliBrite/GloBrite LEDs, IntelliTouch w/Screenlogic2. 400K BTU heater. A&A G4V in-floor cleaning system. WetEdge Prism Matrix Pebble finish. TechoBloc Pavers and Coping.
    Test kits - Taylor K-2006 FAS/DPD, K-1766 Salt, SpeedStir
