Thread: Pool Proof (borate)
    whataboy's Avatar
    Jan 2015
    Lewisville,Texas
    53
    Question Pool Proof (borate)
    Just purchased 4 gallons Pool Proof but before adding I was wondering what would happen if levels falls below 30ppm or goes above 50ppm? From what I read it doesn't raise anything like CYA or CH
    Have done lots of research on the product and really can't find anything negative. Suppose to stabilize PH & TA as well as making water sparkle more. My numbers are spot on and the water sparkles already. Please advise. Thanks!!!
    Rick T.
    12,000 gallon IG Kidney shape,gunite,white plaster w/25% blue quartz (Chlorine)
    Jandy LED Multi-color pool light, ,Pentair VS Pump,Pentair FNS 48 DE Filter,Polaris 280 Cleaner
    TF-100 test kit, Taylor K-2006 test kit, Speed Stir, BBB Method, PoolMath, TFPC
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Pool Proof (borate)
    I'd like to know too. I believe it just becomes too diluted below 30 for the positive effects. I converted to a Borate pool 6 months ago, and it does seem to have helped stabilize the TA, PH, and is sparkling.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Borates below 30 are harmless, but considered ineffective. Borates above 50 or so exceed the (very conservative) epa limit. Borates up to 80 is considered normal for baqua pools, so nothing dramatic starts happening right at 50. For a chlorine pool there is no real point in going over 50, and if you accidentally go over a little it is not a big d
