Thread: INTEX Easy Set ...HELP???
    May 2015
    barnegat,nj
    1
    I have had these pools for many yrs. and using a skimmer. Bought the 18x48 and came with 2 (new) intake hoses rather than 1. NOW...there isn't enough suction to operate either the old skimmer or the newer deluxe version that I also purchased. HELP???
    Do I remove 1 of the extra intake hoses??
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,524
    Re: INTEX Easy Set ...HELP???
    Do you have a plunger valve(s) you can use to close one of them off? Or get a bigger pump, if you're using the one that came with the pool. The Intec pump/sand filter combos are a nice upgrade.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
