Thread: Pool Math
    May 2015
    Burlington, Wa
    8
    Pool Math
    I am having trouble balancing my water, using BioGuard water tester at pool store and 6way tester, Wating for my TF 100 to be deliverd.
    FC .2 ADDED 3QT 1 CUP LIQUID CHLORINE
    PH 8 ADDED 1 QT 6 OZ ACID
    TA 117
    CH 36 ADDED 3 GAL 3 QT CALCIUM CHLORIDE
    CYA 0 ADDED 3QT 3CUPS STABILIZER
    BORATE 12
    TESTED WATER 2 DAYS LATER
    FC 1 ADDED 3QT 2CUPS LIQUID CHLORINE
    PH 6.6 ADDED 4.8 BOXES BORAX
    TA 67
    CH 40
    CYA 28
    BORATE 60
    TESTED WATER 4DAYS LATER
    FC 5.5 ADDED 1QT 1CUP LIQUID CHLORINE
    PH 8.3
    TA 133
    CH 171
    CYA 57
    BORATE 38
    So with a PH of 8.8 BioGuard testing says to add 4.5 pints of acid and pool math says 1gal 3cups, Why the big differance?
    Also he water is stil cloudy will dialing in the PH clear it up?
    Thanks wgcole
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Pool Math
    I would relax and wait for the TF-100 to be delivered. Pool-store and TFP methodologies are incompatible, so you will need to choose one or the other. Tens of thousands of members (and more if you include the lurkers to this site) use the TF-100 or K-2006 along with Pool Math to manage their pools with spectacular results.
    May 2015
    Burlington, Wa
    8
    Re: Pool Math
    Ok Thanks, What do you think of the pool conditions, Its is still cloudy will lowering PH solve this?
    And I filled out a signature, Why didnt it post?
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Pool Math
    If the pool is cloudy, lowering pH will likely not solve it. You will have to SLAM, and for that you need the test kit.
    I'm a recovering Bioguard user as well. My advice is to just wait for the kit. Spend your time reading and learning. If you attempted to make any changes based on the bioguard test results, you would likely accomplish nothing except lighten your wallet.
