Thread: Sand filter installation question
    May 2015
    Washington il
    27
    We purchased a new sand filter due to a large crack in our old one. After redoing all the plumbing and putting new sand in the new filter we connected the multi port valve but only to find the top of th sand filter vessel is uneven by about 1/8 of an inch in one side. So it leaks. Ugh! Is there some sort of self leveling gasket or is the vessel a lemon?
    April's Avatar
    Apr 2014
    KY
    138
    Re: Sand filter installation question
    Did you lube the O ring?
    If not this will cause it not to seat properly and leak.
    Just fixed this same problem with mine this past weekend.
    18ft Round AG, Vinyl, 100LB Pentair Sand Filter, 1HP, June 2012, TF-100 w/SpeedStir
    May 2015
    Washington il
    27
    Yes we did but the problem is that the o-ring doesn't have a flat even surface to sit on top of. The flange is uneven..:seems defective. Is there some sort of self forming gasket? The oring won't seal bc there's a gap.
    April's Avatar
    Apr 2014
    KY
    138
    Maybe a picture would help.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It may sound over simplified, but perhaps you cross threaded just a bit. Easy to do that on my SF top.
    Essential Links:
