Results 1 to 9 of 9
Thread: Chlorine level increases as it sits??
    Jul 2014
    Sacramento/CA
    11
    I use the TF-100 test kit. Whenever I am testing for chlorine, whether it's free or total, I have noticed that as it sits it reads a higher level. In other words, when I first drop the 5 drops of test in the tube it is pale yellow, within as little as 10-15 seconds it is brighter yellow (or, is already reading a whole point higher). Same with the pink of the free chlorine. I could add a few drops of the test and it turns clear and stays that way for many seconds after swirling, then I look back at it a minute or so later and it's bright pink.
    So, my question is, when is the best time to record the correct reading for chlorine? The second I am done swirling the test tube, or 10 seconds later, 20...???
    Thank you!
    PS. I use a salt water system, but shock and increase with bleach.
    Above ground, 10k intex vinyl ultra frame pool. Intex saltwater-sand filtration. Installed May 2014. TF-100 test kit, plus Taylor K-1766 salt test.
    38,548
    Re: Chlorine level increases as it sits??
    With the OTO test, a darkening points to the presence of CC.
    For the FAS-DPD, add drops until it is clear and you are done with FC, then immediately do the CC test. It will always go back to pink if it sits.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Something doesn't sound right.
    Pale yellow isn't a normal color. Here's the video on the test: FAS/DPD Chlorine test for the TF-100 - YouTube
    Here's all the test videos: https://www.youtube.com/playlist?lis...8E18E2EE701C4D
    Jul 2014
    Sacramento/CA
    11
    Quote Originally Posted by bobodaclown View Post
    Pale yellow isn't a normal color. Here's the video on the test: [url="https://www.youtube.com/watch?v=PHQG4tgQsFE"]FAS/DPD Chlorine test for the TF-100 - YouTube[/url
    My question is in regards to two different chlorine tests. When I was referring to the pale yellow, I was speaking about the total chlorine... the one that uses the R-0600 drops. I know the pale yellow still indicates a problem... too low of chlorine. I am currently working on SLAMing my pool from opening it up for the first time this year.
    Back to my question... When I read the results of the chlorine (the total chlorine with the R-0600 drops) should I read the immediate results... like, just a second or so after swirling? Or, should I wait 10 seconds or more????
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Read upon swirling. Don't wait ten seconds.
    Essential Links:
    Jul 2014
    Sacramento/CA
    11
    Got it! Thank you. As you can see (or may have guessed) I am opening my pool for the first time this year, and it needs to be SLAMed.
    Quote Originally Posted by Patrick_B View Post
    Perfect! Thank you again!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    That's ok, you are on the right track, and all the help you need is here. Good luck on it, you'll be very pleased when it's done.
    Essential Links:
    38,548
    Or just skip the OTO test and stick with the FAS-DPD for now.
    Apr 2011
    Murrieta, CA
    2,360
    Sorry I've only used the FAS-DPD test never the OTO.
