Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Help with green pool
    Jun 2014
    Thompson, ND
    33
    I'm trying to clean my green pool. Here are the numbers
    TA 70
    Ph 7.6
    CH 90
    Fc 0
    Stabilizer 50
    Seems like ok numbers. Should I just start pouring bleach in to shock it and clean it up? I have a 30 foot round above ground pool. 52" tall. I believe it's 21000 gallons. Vinyl liner.
    21,000 gal AG 30 foot round pool. Sand Filter. 1.5 hp pump.
    360 gallon 2015 relay hot springs hot tub
    North Dakota
    Jun 2014
    Thompson, ND
    33
    Re: Help with green pool
    Quote Originally Posted by dozer11 View Post
    TA 70
    Ph 7.6
    CH 90
    Fc 0
    Stabilizer 50
    Here is a pic. And my husband vacuuming.
    North Dakota
    April's Avatar
    Apr 2014
    KY
    138
    What test kit are you using?
    18ft Round AG, Vinyl, 100LB Pentair Sand Filter, 1HP, June 2012, TF-100 w/SpeedStir
    Jun 2014
    Thompson, ND
    33
    Taylor. Except the stabilizer was from a test strip.
    North Dakota
    38,524
    Step away from the test strips, they are garbage.
    Which kit specifically?
    Jun 2014
    Thompson, ND
    33
    K-2006. I agree about the strips. What a pain. I was desperate though...
    North Dakota
    April's Avatar
    Apr 2014
    KY
    138
    I have the TF-100. So I'm not familiar with that specific test.
    Can you test CYA with it? ( instead of the strips)
    Your SLAM LEVEL depends on you CYA level. So you want to make sure you have a good reading.
    Otherwise you will either waste a lot of chlorine or not use enough to clear the pool completely.
    38,524
    Use the K2006 to test the CYA.
    Jun 2014
    Thompson, ND
    33
    I will do that after work with the k2006. I am out, or almost out of that test. I will need to order more.
    North Dakota
    Jun 2014
    Thompson, ND
    33
    K2006 cya test says 55. Should I drain some water or go ahead with slam?
    North Dakota
    38,524
    SLAM away, that CYA is reasonable.
    Jun 2014
    Thompson, ND
    33
    Here is a complete test result list
    CYA 55
    FC 7
    Cc 0
    PH 7.7
    TA 70
    Is that ph acceptable for SLAMing? I put in 3 gallons of bleach last night before bed. Water looks a lot clearer.
    North Dakota
    38,524
    First step listed in the SLAM article is to lower the pH
    Jun 2014
    Thompson, ND
    33
    Does SLAMing raise ph?
    North Dakota
    38,524
    Whenever you add FC with bleach it raises the pH ... which is why you should start with a low pH. Since you can not test the pH while the FC > 10ppm.
    When the FC is consumes, the pH comes back down making the bleach effectively pH neutral.
    Jun 2014
    Thompson, ND
    33
    Good to know. I added bleach last night so that's probably why it was higher today. Thanks!
    North Dakota
    Jun 2014
    Thompson, ND
    33
    I've been SLAMing, brushing and vacuuming and I THINK (not quite sure) the water looks clear, but let me know what you guys think please! I'm keeping the pool at SLAM levels through today and will test the Overnight chlorine loss tonight. Do you guys think the water needs to be clearer? I will attach a picture, but I can see the wrinkles clearly on the bottom of the liner, so I think that is a good sign. I know that I need to vacuum the middle, I just need to get in the water to do that, or let Diver Dave out for another few hours.
    North Dakota
    38,524
    Looks pretty clear ... I would get that dirt out one way or another though.
    Jun 2014
    Thompson, ND
    33
    Thanks, I'll put my husband up to it! I'm in North Dakota, so the water is still pretty chilly :/
    North Dakota
  20. Back To Top    #20
    Jun 2014
    Thompson, ND
    33
    My water is clear. The CC is 0 and FC lost 3 ppm overnight. It was 17 last night and 14 this morning, but it rained pretty good here last night. Should I continue to keep the chlorine at SLAM levels or would I be wasting bleach at this point. I'm wondering if the rain was the culprit for the extra loss of 2 ppm.
    North Dakota
