Thread: pump sucking air after about a minute (video included)
    May 2015
    Roseville, MI
    10
    I thought my woes were gone as this has been the longest I can keep a solid flow (raised the water level) I've replaced the cap gasket, drain plug on filter (was leaking) tightened the drain on the basket. This is all new to me and this is a great place, any ideas? air starts at about 1:10 Air leak - YouTube
    22K Inground swamp, concrete, hayward SP, sand filter.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: pump sucking air after about a minute (video included)
    Is a whirlpool forming in the skimmer causing the pump to suck air?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Here is a helpful article from Pool School - Suction Side Air Leaks
    May 2015
    Roseville, MI
    10
    Thank you for the article. The I can't see a vortex when it's running, in fact it doesn't seem to move much water at all.
    30,403
    the problem is very simple......You are sucking air from somewhere from the skimmers to the pump........ the solution is sometimes hard to find.
    For an air leak that "lets go" that fast, I suspect it is at the skimmer.
    Post someone at the pump, then go to the skimmer and observe what happens when the pump breaks prime......I think you'll see it.
    Jun 2014
    Mono/Ontario/Canada
    24
    My skimmer weir was broken and not letting in water causing the same thing... Took ages for me to figure it out
