Results 1 to 14 of 14
Thread: Pool/Deck Install Finished Finally!
    Chuppa3's Avatar
    May 2015
    Sagamore Hills, OH
    65
    First full year with the pool. Construction just finished last fall on the pool. Legacy pool here which is similar to splash pools. Liner never needs replaced so deck can be built right over pool edges. I really took advantage of it. Father-in-law helped build custom bench with storage you can see in pics below and now we have two matching gates. I installed fence and did some work on the railings. Had carpenter do deck supports and deck flooring. I also did lighting which you can see on step up in deck and steps. All pool equipment is hidden in a door on left side of the stairs.
    17x32 Legacy Pool / Deck built around entire pool / Hayward EC40C92S Perflex 1-Horsepower Extended-Cycle D.E. Filter / Dolphin DX-3 / GLI Cyclone Solar Cover Reel / TF100 Test Kit/Raypak 266k BTU Cupro Nickel Gas Heater
    Pool/Deck Install Finished Finally!!
    Chuppa3's Avatar
    May 2015
    Sagamore Hills, OH
    65
    Re: Pool/Deck Install Finished Finally!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Wow! Very nice work!
    Chuppa3's Avatar
    May 2015
    Sagamore Hills, OH
    65
    Quote Originally Posted by pooldv View Post
    Thanks!
    May 2015
    Gulfport, MS
    109
    Looks great, kinda wish I went with a rectangle
    12X20x54" Saltwater 8000 semi-inground, Waterway 1.5hp 2speed 22" Pump Sand Filter, Hayward Goldline Aquatrol HP SWG, TF100
    Chuppa3's Avatar
    May 2015
    Sagamore Hills, OH
    65
    Quote Originally Posted by Straight6tt View Post
    Thanks! I love the rectangle.
    *JLS*'s Avatar
    May 2014
    Central Georgia
    60
    That is beautiful! Very nice work!
    What kind of plants is that there on the right side of your steps? I need some of those!!
    ​Jennifer
    19k gal, 27' x 54" AG Aqua Leader Saltwater 8000 installed April 2014; Aqua Pro 19" Sand Filter System 1.5-hp Pump; Hayward Aqua Trol Salt Chlorine Generator System; Overlap Boulder Swirl Liner; Polaris 65 Turbo Turtle Automatic Cleaner; TF-100 Testing Kit
    PoolESQ's Avatar
    Dec 2007
    Albuquerque, NM
    191
    What a beautiful pool! I've always had a fondness for wooden decks, they are so classic. Congrats!
    By the way, what makes it so the liner never has to be replaced?
    Replastered 2015: Sunstone Quartz Midnight Blue 16x32 rectangular gunite with in-pool spa....18,000 gallons. Autopilot Total Control System with SWG and acid pump. Pentair Clean & Clear 420. Auto cover. TF-100.
    Chuppa3's Avatar
    May 2015
    Sagamore Hills, OH
    65
    Quote Originally Posted by *JLS* View Post
    Thank you ! Those are hostas, early in the season they look like that and eventually they bloom flowers on long stems.
    Quote Originally Posted by PoolESQ View Post
    Thank you! The pool and the liner is all one piece. The pool is made of material, the walls and the floor, that is super thick and used in navy seal parachutes. The pool itself is like a big balloon. Outside of the base galvanized steel beams push against the walls and the water pushes back. You don't drain the pool in the winter because that is what gives it strength.i don't want to post any Google pics because of copyright issues lol but Google splash or legacy pools and look at the construction. The structure of my pool is completely hidden.
    PoolESQ's Avatar
    Dec 2007
    Albuquerque, NM
    191
    Great find! I'm very envious of your pool/deck. Hope you make a lot of good memories with it!
    Chuppa3's Avatar
    May 2015
    Sagamore Hills, OH
    65
    Thanks ! I appreciate it!
    Apr 2014
    Manitoba, Canada
    70
    Love your build!! Great job
    Our "Backyard Oasis" 2014 12x24x52" Steel Pro Hydro Force (Bestway) 7725 gallons; Jacuzzi 1LRC-5-S1/B 1HP Pump: Jacuzzi L192-7C 19" Laser Series Sand Filter; KStar 10 10KW Electric Pool/ Spa Heater; Jacuzzi wall mounted skimmer
    Chuppa3's Avatar
    May 2015
    Sagamore Hills, OH
    65
    Quote Originally Posted by ariel68 View Post
    Thank you!
    Chuppa3's Avatar
    May 2015
    Sagamore Hills, OH
    65
    Just added some more pics to the photobucket of surrounding area.
