Thread: How to access Hayward Power Flo Matrix impeller?
    May 2013
    Reading, Pennsylvania
    4
    I have the dreaded humming pump and after reading several threads, I thought if we could spin the impeller, we may be able to free up something.
    The problem is, I can't access the impeller. We have a Hayward Power Flow Matrix 1 hp that has only been used for 2 seasons. My husband took the pump apart on the wet end and you can see the impeller is behind another piece of plastic. You can see and touch the rounded end, but the blades are barely visible. I can get my finger in to touch them, but can't move them. Any suggestions?
    I found a photo of the impeller for my model, an SP1510Z1XEHC, and am attempting to attach it to this post.
    Thanks!
    24' AGP
    Hayward DE filter
    Hayward 1 hp Power-Flo Matrix
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: How to access Hayward Power Flo Matrix impeller?
    on the back end of the motor there may be a cover to remove and you can access the shaft at that end.
    May 2013
    4
    Thanks Bobo. We did access the other end and the impeller won't budge when trying to turn the shaft with a screwdriver. My husband also can't get the impeller off or get in from behind it to see if there is any debris in there.HaywardPumpBottom.jpgHaywardPumpImpellerEnd.jpgHaywardPumpWetEndSwivel.jpg
    24' AGP
    Hayward DE filter
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Does the motor end have a nut on the shaft that you can put a wrench on? That'll give you more torque than a screwdriver. With it open like that, you can't turn the impeller at all? That whole piece should spin, not just the blades inside it. You should be able to hold the nut on the shaft, and spin the impeller counter-clockwise to unscrew it.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Looks as if the motor may have been sitting in some standing water or the seal has been leaking.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
