Thread: Re: Need To Reset Pentair Intelliflo
    May 2015
    ca
    2
    Split from Need To Reset Pentair Intelliflo
    I've tried resetting it as described but with no luck. I have the same problem caused the same way except I turned off the breaker not an electrician. Can not figure it out possibly. I've tried a lot of times. Pool is starting to turn green as its been almost 5 days without action. Please help
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    I believe when I have turned off the circuit breaker to my pump when restarting I have to push the stop/start button and it says 0rpm with green light and then push a speed button.
