Results 1 to 7 of 7
Thread: Backfill AGP questions
    May 2015
    Pittsburgh/Pennsylvania
    27
    Hello, just got done excavating for our pool. We over-dug by about 4 feet. The high side had to be dug down about 3 feet to get it level. My question is should I build a retaining wall or backfill up to ground level? What other options do I have? Thanks!
    21' 54" round AGP, Hayward 1hp 2 speed pump, Hayward Aqua Trol HP SWG, Hayward 150 sq ft cartridge filter
    Feb 2015
    Bardstown KY
    139
    Re: Backfill AGP questions
    We just had this same dilemma, and received conflicting advice. Debated for ages and eventually built a retaining wall around 3/4 of the thing. I just knew that if we backfilled I would always worry that it was causing problems I wouldn't see until it was too late.
    27k gallon 33' round, partially buried 22" Sandman sand filter, 1.5hp 2 speed TidalWave pump, Pentair 'Lil Shark with leaf canister, TF-100 Test Kit
    May 2015
    27
    Same here. I know from experience you want as much of your walls exposed as possible. You don't wanna have to dig it all up if there is a problem. What I am thinking I'm gonna do is just slope the high side a little more with a shovel and build the deck right over it. Just do plastic, french drain pipe, and gravel around the backside (the side into the hill) and leave my walls exposed.
    May 2015
    pittsburgh pa
    62
    Quote Originally Posted by bighendy View Post
    thatd what I have.
    11,000 gal (21' round) AG
    DE EC40
    Feb 2015
    Bardstown KY
    139
    Yup, that is EXACTLY what we did! Well, river rock instead of gravel.
    May 2015
    27
    Sounds like I'm on the right track the. Thanks!
    Jun 2014
    Blue Springs, MO
    14
    The warranty for my pool allows it to be buried up to 18". I back-filled to that height, then built a retaining wall to hold back the remaining slope. It only took 2 courses of your standard pavestone type block for me to get back to grade. It is soon to be hidden under a pressure treated deck.
    Above Ground 30' x 52" AquaLeader Blues pool
    Pentair Dynamo 120v 1.5hp pump w/Sand Dollar 40 filter
    Hayward Skimmer
    TF-100 Test Kit
    Pool installed and filled 6/27/14
