Thread: request for vacuum advice
    Oct 2007
    Central Texas
    I need a vacuum that can handle the fine dust/dirt which collects at the bottom of my pool. leaves are not a big deal for me. It must have an option switch to stay on the floor.
    I don't care if its suction side, pressure, robot, dust fairy, anything!
    It needs to last for a couple years after which my son will be big enough to be crowned "pool boy".
    Light grey plaster, stone coping, 38K gallon Roman shaped pool with a shallow end beach, table and bar stools, deep end bench and waterfall (Intelliflo 4X160). Taylor K-2006, Pentair 320 chlorinator, Intelliflow VF, Quad DE 100. 4 ColorLogics, 3 skimmers, 14 wall returns, 13 floor returns, TurboTwister slide, autofill and miles of pvc.
    Re: request for vacuum advice
    Polaris 280 Or Letro Legend.
    Use the fine bag or add a nylon liner to the bag.
    These are both pressure side cleaners that utilize booster pumps.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    Apr 2008
    Central Texas
    Another vote for the Polaris 280 with the fine bag. Mine doesn't leave anything behind that is visible and I'm often amazed at the fine grit that I find trapped in the bag. It also seems to be the most rugged design of the various Polaris pressure side cleaners.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    If you only need a few years out of it, a remote controlled robotic cleaner can be a lot of fun. You can clean your pool with one hand and drink a beer with the other. Expensive, but worth it?
