Thread: Helping a friend out and pump just broke
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    I helped a friend open his pool about 2 weeks ago. Algae was present upon opening the pool. Either the pool was not closed properly or the safety mesh cover allowed too much sunlight in. We SLAMMED the pool and finally it seemed that we were all done.
    The testing this evening reflected FC of 5 and CC of 2. A bit strange as the last week's testing was showing the CC was .5, and water was clear. It is possible the testing was done incorrectly, but I doubt it. And yes, we are using the TF - 100 test kit.
    It appears that the pump impeller broke this evening. With these levels, algae may be back sooner than later. He was able to take the pump off and now it is getting darker. It could take a few more days before the pump is replaced as the plumbing is not exactly user friendly, making it easy to replace the pump.
    Question: What should we do next given these circumstances? Can we dilute liquid chlorine in buckets and broadcast all around the pool without the filter running? Should a cover be placed back on the pool? Should there be an algaecide used for the next few days?
    This could take a week before the pump issue is resolved. Thank you.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    38,429
    Re: Helping a friend out and pump just broke
    Yes you should continue to add bleach, use a brush to thoroughly mix it in.
    Yes a cover could help keep the FC around and block the sun.
    You could use some Poly 60 as insurance if the FC drops too low.
