Thread: Polaris 280 input needed
    May 2015
    TN
    312
    I have a Polaris 280 that came with the pool when we purchased our house. It is 10 years old. It is wore considerably along with being bad faded, and I can see a few cracks in it. Fittings are all rusted as well. If I had to guess, it was left in the pool all season long and never took out of the pool.I looked on youtube to get a basic feel on how to hook it up and use it as far as not to mess the pump up. However, I don't really know what to expect out of it because I have never been around this type of vacuum. What I have noticed is it does good for a few mins. and then floats or hovers around close to the bottom more than anything. I have taken it out and cleaned the bag but same thing. Another thing I have noticed is where it plugs into the pool wall there is some water pressure coming out from around the fitting. I don't know if this is normal. If it gets hung up in a corner it will just sit there and spin its wheels. I don't want it to hurt the liner doing that. I guess my question is, is any of this abnormal and can anyone tell me what I should be expecting out of it? It fills the bag good when it is running good, but it seems like he plays hovercraft more than Mr. Vacuum guy.
    24k gal. In-ground, vinyl. 2005 build
    Hayward Pro-Series S244T sand filter system
    Hayward motor & pump (rpm 3450,model SP2607X10)
    Polaris 280 w/booster pump.Taylor K-2006 test kit
    May 2015
    TN
    312
    Re: Polaris 280 input needed
    Anyone?
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    The backup valve is supposed to come on occasionally to pull it up in case it gets hung somewhere. It may be leaking and staying open enough to pull it off the bottom. I've seems few threads where people talk about the relief valve in the wall plug is staying open with water coming out like you describe. So, either or both of those could need to be replaced. Another possibility is its getting too much pressure from the booster pump. Does the port in the wall have a blue or red disk installed in it? When you set them up you start without one, then if the wheel rpm is too high, you add one to reduce the amount of water going to the cleaner to slow it down.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    the 280 should be running at approx 28 - 32 psi, rule of thumb 1 wheel revolution = 1 psi. so you turn the cleaner on and hold it under the water and count the wheel revolutions in 15 seconds (then times that by 4 and that gives you revolutions per minute). at the wall fitting you should see a large nut with a coloured disk in the middle (pressure bypass valve) you then screw this nut in to speed the cleaner or out to slow the cleaner, adjust it so you have the rpms at the cleaner and all should be good to go. check the rear float on the cleaner to make sure it does not have water inside.
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
    Mar 2015
    New Orleans, LA
    81
    Bring it to a pool store and see if they can recondition it. Usually cost a few hundred so you have to decide if its smarter to just get a new one. You can buy rebuild kits online but I think they are not cheap.
