Results 1 to 10 of 10
Thread: Help!! Golf ball got sucked into main drain
    May 2015
    GA
    4
    A golf ball got sucked into my main drain. I have no idea how to get it out, I've trying running a snake on both ends but I have too many 90 degree bents in my pipes for the snake to get far enough to the ball. Any help would be greatly appreciated.
    38,290
    Re: Help!! Golf ball got sucked into main drain
    Welcome to TFP!!!
    Begs the question, why do you have not a drain cover?
    Try forcing water from the pump back toward the floor drain. Wrap a rag around a water hose.
    May 2015
    GA
    4
    I took off the drain cover when I was cleaning the pool and forgot to put it back on. I can't get the water hose far enough in the pipe to generate enough pressure to do anything.
    38,290
    You do not need to get the hose far into the pipe, you need to try to seal around the hose so you can generate some pressure/flow.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Can you get in the pool? How about hooking a vacuum hose up to the skimmer and then swim down to the open drain with it and get some flow that way? Unless the ball is wedged in there, it should just take some current to roll it out.
    May 2015
    GA
    4
    Tried the vaccum thing didn't work it must be wedged in there.
    Is there anyway to purge the system. I'm stupid when it comes to pools but I'm trying to learn.
    May 2015
    GA
    4
    I finally got it. I used an air compressor and blew it out.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Woohoo! Good deal!
    Essential Links:
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    nice
    Jul 2009
    Long Island, NY
    267
    There's something I bet you'll never do again. Glad you got it out.
    Free-form concrete walls with vinyl liner, 18,000 gallon capacity, Jandy 1.5HP e-Pump, Jandy DEV48 DE filter (using cellulose media), Jandy AE2500 heat pump, Jandy Aqualink Power Center with 14-blade cell kit and Jandy PDA-P8 wireless control system.
