Thread: hand pump to transfer chlorine from 5 gal. carboy to 15 gal container
    Jul 2011
    North East
    135
    I'm looking for suggestions on making the transfer of chlorine from the 5 gal. carboy to the 15 gallon container for the stenner pump. Currently lifting the 5 gallon container and pouring into a make shift funnel into the 15 gal container but often spill a good bit and make a mess.
    looking at hand pumps potentially but haven't found anything to fit the bill.
    25,000 gallon Concrete/Plaster Pool
    Pentair WFDS-26 - Installed Spring 2012
    Pentair Quad DE 100 - Installed Spring 2012
    Pentair Kreepy Krauly 820 - In Service 05/26/2013
    K-2006 Test kit, Intermatic P1353me Digital Timer, Stenner 85MHP5
    May 2015
    South Park, PA
    39
    Re: hand pump to transfer chlorine from 5 gal. carboy to 15 gal container
    Have you checked Grainger.com or MSCdirect.com. They have hand drum pumps (for 55 gal drums). Maybe they have smaller hand pumps.
    30,000 gal inground (20 ft. x 40 ft. w/ deep end), vinyl liner, Pentair Clear & Clear 420 cartridge filter, single speed 1.5 HP Pentair Whisperflow pump, heat pump, SunTouch controller
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Northern Tool might have something.
