Thread: TA question
    Jul 2014
    Evansville, IN
    72
    TA question
    I had a new liner put in and filled with fresh city water- All my numbers are good except TA- it was 190. As a result, I poured in Muriatic Acid and lowered PH to around 7.1. I aerated to bring PH back up (it's now about 7.8) and my TA is 140. Should I do this one more time to get TA down around 120? Or should I just watch the PH closer and only add acid if it rises higher?
    Thanks.
    16 x 32 Sport Pool; Hayward Series Sand Filter S244T
    15,000 Gallons, In Ground with New Vinyl Liner
    Pool approx. Five Years Old. Live in KY
    38,548
    Re: TA question
    Up to you.
    If the pH is stable, then the TA is pretty irrelevant. If the pH keeps rising, then lower the TA some more.
    Jul 2014
    Evansville, IN
    72
    Re: TA question
    Should I remove solar cover if I add a little acid?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: TA question
    Yes that is a good idea so you don't burn your cover.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Jul 2014
    Evansville, IN
    72
    Re: TA question
    Thanks
