Thread: New filter media for sand filter!!?
    Victor's Avatar
    Girard, OH
    38
    Hello all I'm on my 3rd yr. of my sand filter and I heard my sand should be replace after about 3 yrs. I started doing research on alternatives and I came across a product called "activate"
    ImageUploadedByTapatalk1432759031.356328.jpgImageUploadedByTapatalk1432759049.662584.jpgImageUploadedByTapatalk1432759057.381633.jpg
    here is the brochure. Has anyone heard of it? It sounds great but not sure if it's all hype or not..
    Thanks in advance guys
    IG, steel walled vinyl liner, approx. 18000 gal. swg ( Hayward salt system), gas heated, with 250 lb sand filter and 1.5 horse pump.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: New filter media for sand filter!!?
    My vote is for hype. Search some older threads using Glass Filter Media
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Sand needing to be replaced every 3 years is a myth. Think of it this way: The sand has been around for millions of years already. Do you think 3 years in a pool filter really is going to change the sand much at all? Not likely.
    If anything, sand can periodically need a deep cleaning but replacement is not necessary. See the procedure for deep cleaning a sand filter here: Deep Cleaning a Sand Filter
    There are many sand alternatives out there. If they work as well as sand depends on the make/model of your sand filter to some extent. Some alternatives can actually cause problems. Some users on this forum have posted problems with the product Zeolite specifically.
    Scare tactics on the chlorine in water is another red flag in the literature.
    Isolated Spa - 345 Gallons
    May 2013
    North East Ohio
    959
    Total scam....run away fast... I had glass and it did not filter. Now I have sand and all good.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Victor's Avatar
    Girard, OH
    38
    Thanks guys!! Always on top of it!!
