Need help with Aquarite Ele Chlorine Generator
May 15, 2015
8
whellerburg ohio
Here my readings on my Hayward AquaRite when I push the button.
3300
82
27.3
4.73
96p
-3100
AL-0
r1.59
E-4
Cheched my ph with pool tester kit and ph showing high.
Chlorine shows low.
I have no idea what these reading are. I have a 16 x 32 x3ft to 5 ft deep
Can someone help me with what I need to do. Pool looks great and water very clear. Thanks!
Average salt level
water temperature
volts dc
amps
percentage run time (3 hour cycle)
Instant salt
Product name code
Software revision number
T cell type (it probably reads t-9)
assuming you have a t-9 cell, everything looks good.
You need to get some chlorine in the pool quickly. You might need to Slam. If you can post all of your chemistry numbers, we can further assist you.
