Thread: Need help with Aquarite Ele Chlorine Generator
    May 2015
    whellerburg ohio
    8
    Here my readings on my Hayward AquaRite when I push the button.
    3300
    82
    27.3
    4.73
    96p
    -3100
    AL-0
    r1.59
    E-4
    Cheched my ph with pool tester kit and ph showing high.
    Chlorine shows low.
    I have no idea what these reading are. I have a 16 x 32 x3ft to 5 ft deep
    Can someone help me with what I need to do. Pool looks great and water very clear. Thanks!
    Re: Need help with Aquarite Ele Chlorine Generator
    Average salt level
    water temperature
    volts dc
    amps
    percentage run time (3 hour cycle)
    Instant salt
    Product name code
    Software revision number
    T cell type (it probably reads t-9)
    assuming you have a t-9 cell, everything looks good.
    You need to get some chlorine in the pool quickly. You might need to Slam. If you can post all of your chemistry numbers, we can further assist you.
    Support the site
    May 2015
    whellerburg ohio
    8
    How do I get the chemistry numbers. I'm dumb here. Thanks for replying.
    You either get an appropriate water test kit, or you have a pool store test the water for you. We recommend getting your own test kit, as pool store results are often quite inconsistent.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Here is a Test Kits Comparison of good test kits. I prefer the TF100 from tftestkits.net
    Here is the information we are looking for about your pool and water chemistry.
    Pool School - Read This BEFORE You Post
    May 2015
    whellerburg ohio
    8
    Thanks pooklv. I took a water sample to the pool store and they tested my water and I got some chemicals and everything back to normal. I stll need to read read and read. thanks againg for your helping me.
