Thread: SWG not producing chlorine?
    jmcdtucson's Avatar
    Jun 2014
    317
    I've noticed my 1-year-old SWG isn't keeping up like last year. Everything reads normal but my chlorine keeps dropping even though I run the same amount (4 hours / day). The idiot lights on the SWG indicate proper operation and the cell is not scaled.
    At first I thought CYA is down. But it was 50 and I've brought it back up to 70 and still my chlorine keeps dropping.
    So today I tested before and after running the SWG for 4 hours. It increased chlorine at most 0.5.
    Next I gathered my sample directly from the return jet. It reads the same Cl as water from the pool in general. Is this reliable?
    Back around May 1 when investigating this, I did a SLAM and OCLT and it came in at 0.5. Pool water is crystal clear.
    Is my SWG fried? Anything else to test?
    Currently my pool is covered most of the time. Not sure if that affects anything.
    Thanks!
    NaCl: 3600 ppm (toward top of recommended, about same as last year)
    CYA: 70
    Borates: 50-80
    Chlorine: TC: 4 FC: 4
    TA: 60
    PH: 7.2
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: SWG not producing chlorine?
    I am not positive but it sounds like it might be?? at 99 dollars I dont think they last very long...
    Amazon.com: Intex 120V Krystal Clear Saltwater System CG-28669 with E.C.O. (Electrocatalytic Oxidation) for Above Ground Pools: Patio, Lawn Garden
    jmcdtucson's Avatar
    Jun 2014
    317
    After reading more, I'm going to at least try cleaning the cell first. I'm also going to run the unit longer before testing the chlorine from the return and see if I see any bubbles coming out.
    I'd suspect sneaky algae, but I'd think I would see SOMEWHAT higher chlorine reading from the return than from the general pool.
    EDIT: I do see the little champagne bubbles coming out.
    Now measuring again after running the SWG for several hours, pool water is at 4.5 (so it produced something today since it was at 4 yesterday) and the water from the return is at 6.
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    Jul 2013
    Fletcher, OK
    3,353
    Well that is a good sign.
