Results 1 to 7 of 7
Thread: Going to start SLAMing on Friday.
    Aug 2013
    East Wenatchee, WA
    20
    This year when opening my pool it was discovered that the old sand media filter was kaput and was going to need some servicing. LocalPoolCo has always been a nighmare to deal with, and this was no exception. Getting them to call me back is like pulling teeth. So eventually I decided nuts to this and ordered a cartridge filter which should be here tomorrow that I plan to install myself. My pool definitely green. I haven't bothered putting any bleach in it since I had no filtration (this may have been a mistake?). So once I get the new filter installed I'm definitely going to have to SLAM for the first time.
    I'm curious, during the SLAM should I keep the pool covered to mitigate FC loss due to sunlight and prevent additional contaminates from entering, or should the pool be uncovered while SLAMing so it can ventilate or something?
    Thanks!
    IG Vinyl. ~28000 gallons. 1.0 HP Jacuzzi Magnum Plus. Hayward C4030 425 Sq. Ft. Cartridge filter. TF-100 (2012-2015) Taylor K-2006 (2016)
    38,301
    Re: Going to start SLAMing on Friday.
    Sand in filters rarely ever goes bad ... might have just needed to Deep Clean your Sand Filter.
    Usually you want the cover off for at least part of the day to let the sun help breakdown the CCs.
    Cartridges can be a bit more of a pain to clear up algae as they may clog up quickly.
    You could certainly start adding in a couple bottles of bleach every day and brush to mix it in ... might help keep the algae from getting worse.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    During a SLAM it is good to let the pool breath, so you should leave the cover off.
    What test kit do you have?
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Aug 2013
    East Wenatchee, WA
    20
    Sorry, by kaput I meant that the sand is all coming out of the filter back into the pool (if the pump is running), or out my drain if I run it in waste mode. Additionally, the location and current setup for my pump to backwash puts me at risk of sending pool backwash down the storm drain (which is illegal here), so it's always been a dicey operation when I've had to backwash the filter. With the cartridge filter I can take the cartridges elsewhere on my property and wash them without having to risk getting a big fat fine, so that will decrease my stress level a bit regardless.
    Quote Originally Posted by Azgirl71 View Post
    Perfect, thanks!
    I have the TF-100. Been using the TF-100 at the advice of this forum ever since I became a pool owner 3 years ago!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Your welcome and Glad you have a great kit!
    Lisa
    38,301
    Please add your location (City, State or City, Country) to your profile as described HERE as it will help us help you.
    Aug 2013
    East Wenatchee, WA
    20
    Done. I'm in a pretty dry climate. Central WA state, east of the cascades (the dry side).
