Results 1 to 8 of 8
Thread: Thanks TFP!
    Thanks TFP!
    In 2013, thanks to this site, I decided to build my own pool. I never had a pool before so I was relying on what I learned here to get me going in the right direction. It's a 26,000 gallon true-L liner pool with a jump board, SWC generator, heater, variable speed pump and a cartridge filter. I have a robot to clean it and considering what it is, I really don't have to do much to take care of it. And because I learned everything about pool care from this site instead of a pool builder or a store, I don't know any better than to use commonly available chemicals like chlorine bleach from the grocery store, muriatic acid from the hardware store and plain old softener salt to balance and adjust it.
    Last winter, I closed the pool with just a dozen or so gallons of bleach and threw the mesh cover on it. After our first true winter in a long time in New England, I pulled the cover off to find a crystal clear (and very full!) pool. I started it up for the season with 5 gallons of bleach, 7 bags of salt and two trips with the robot and it was perfect. I think my total outlay for startup was around $50.
    Just thought I should thank everyone here for their questions, answers and support. I'm pretty sure my kids, their friends and my neighbors would say thanks too.
    DIY 28x38x18 Full L, 26,000 gallons, Pentair VS Pump, SWG, CCP 420 Filter, Sta-Rite Max-E-Therm SR400HD Heater, EasyTouch Controller
    38,235
    Re: Thanks TFP!
    Congratulations!!! sounds like you are a enjoying a truly trouble free pool
    One way to show your gratitude and help us keep the lights on to help others is to become a supporter (see link in my signature)
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Thanks TFP!
    Woohoo! Glad you're sticking with it and saving cash while having a gorgeous pool.
    ... and what jblizzle said.
    Isolated Spa - 345 Gallons
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Re: Thanks TFP!
    excellent! It works don't it!
    Divin Dave,
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Thanks TFP!
    That is great!
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Thanks TFP!
    Don't you just love it when a well-executed plan comes together?
    Re: Thanks TFP!
    Reminds me of a plaque I bought years ago for a friend with a boat that said "This boat runs on gas, not thanks." Yes, I do need to become a supporter. Although being so cheap that I built my own pool it does go against my nature somewhat!
    Jun 2014
    14,951
    Re: Thanks TFP!
    I can relate to your message DIY. Hope you can post a pic or two later to show us your oasis. Enjoy your swimming season.
