Results 1 to 10 of 10
Thread: Greetings from Clearwater Florida
    May 2015
    Clearwater/FL
    4
    Hello all.
    Surfing the net for ideas on better pool practice and found myself ashore here. Not new to pools but far from a pro either. Always looking for that fine line to reduce running cost and increase longevity of everything.
    Next project is to figure out how to deal with the fixed drain line from the DE filter. Then of to finish all the automation...
    53K Gallon, 4 return, 1 skimmer, 1 dedicated vac line Marcite pool (10' deep)
    3hp intelliflo pumps, 60SQFT Pentair DE filter, Pentair easytouch automation
    Pentair intellichlor salt chlorine generator, 2x Intellibright LED lights
    750 Gallon 8 jet, 2HP blower 2HP Pump, spillover spa with 300k BTU gas heater
    38,262
    Re: Greetings from Clearwater Florida
    Welcome to TFP!!!
    That is a BIG pool
    Care to offer up some pictures
    Jun 2014
    15,054
    Based on the equipment in your signature, you look like you have been around the (pool) block once or twice for sure. Hope you find the TFP site rewarding to your pool maintenance practices. Post some pics some time.
    May 2015
    Clearwater/FL
    4
    55 feel long- 17 wide at narrow and 29 in "L" area; 4 foot shallow down to a little over 10 foot in the bowled "L".
    38,262
    Where did you find that rustic corrugated metal? I am looking to do something very similar.
    Those almost appear like there was a treatment done to them to have uniform rust.
    May 2015
    Clearwater/FL
    4
    Actually, they are asphalt roof panels with high temp and wind ratings (hurricanes are great for wind surfing not so great for roofs). There is a little bit of insulation under for the heater and to aid in heat dissipation. They use them in industrial and restaurant settings- thought they would do well there.
    38,262
    Hmmm .. interesting.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Those roof panels look like what I used on my pool hut. Ondura 4-ft x 6.58-ft Corrugated Cellulose Fiber/Asphalt Roof Panels. I've been very happy with them. Easy to work with and have held up great for 4 years so far.
    Shop Ondura 4-ft x 6.58-ft Corrugated Cellulose Fiber/Asphalt Roof Panel at Lowes.com
    oh, Welcome to TFP!
    Nice Pool and equipment shed!
    May 2015
    Clearwater/FL
    4
    That looks like them. Not sure what make or model. Got them from co-worker; we work for a chemical company and these were slated as trash. They are heat and wind rated so good enough for me; bonus was matching my roof.
    Shed is a work in progress- still placing the pebbles, decking, camera system and lighting out there.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to the forum!
