Thread: Need Help Finding A Ladder
    Z7What's Avatar
    Mar 2015
    New Orleans Area
    141
    I have this ladder that I use lag bolt type bolts to attach it to the deck. We're the bolts go through it is starting to crack so I'd like to replace it. Just not exactly sure what kind of ladder to get. Ideally one that easily attaches and unattaches from the deck would be best so the LiL Shark doesn't get caught up in it.
    This is what I have now.
    Wayne
    24'X54" Round 15,000 Gallon Pool
    Pentair SD-60 Sand Filter With 1.5HP Pump & Center Floor Drain
    Lil' Shark Vacuum With Leaf Canister
    New TFPC User And Couldn't Be Happier
    Pool School + Test Kit + Pool Math = A Perfect Trouble Free Pool
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Need Help Finding A Ladder
    I really like the Confer ladders. There are a variety on Amazon.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    38,301
    Seems like the ladders that sit in sleeves on the deck might be a little easier to pull in and out.
    Casey's Avatar
    SW PA
    10,446
    This is what my brother has.
    Z7What's Avatar
    Mar 2015
    New Orleans Area
    141
    Could yall post pictures? Im having a hard time finding a simple angled ladder that has cups that would mount to my deck to make removing the ladder easier.
    Wayne
    Apr 2013
    Argyle, TX
    77
    Pool Deck Ladders
    This is the brand we use and you can find then at most online pool supplies and amazon/ flebay
    21' NEW YORKER II 54" DEEP AGP Private Label MORADA RTR WILBAR Aluminum wall
    Hard Bottom and 1/4" Floor Pad 1/8" Wall Foam Well Water Perma 2500 Unibead liner King Technology Pool Chlorine Feeder HAYWARD Diver Dave cleaner
    Waterway 22″ Sand Filter 1.5 HP Center Discharge Pump Single speed Wide Mouth skimmer
