Thread: Losing 1/2" when pump running
    Aug 2013
    Ontario Canada
    17
    Hi guys,
    Fixed a leak at the pump this spring when I noticed small bubbles coming out of the return and now the pump basket has very little air in it. However, in the last 2 weeks or so we have been losing 1/2" a day but only when running. Bucket test proved not evaporation. I dye tested and the openings in the pool itself. No water coming out of backwash line. I replaced the spider gasket last summer. The only thing about the filter, is when I turn it off I can hear air entering from somewhere. Other than that, there is no standing water anywhere around the pool so no underground noticeable leak. Any suggestions greatly appreciated.
    Bluegirl
    28000 gal in-ground, vinyl liner, Hayward Sand filter, 1 hp Sta-Rite pump single speed , TF-100 test kit, Sunheater solar heat, Hayward 250,000BTU heater.
    38,474
    Re: Losing 1/2" when pump running
    Losing more water only when the pump is running points to a leak on the pressure side. Since you do not see water coming out by the equipment, it could be in the underground pipes. Not sure how to suggest locating it though.
    Air should not be able to enter the system when the pump turns off, so you have a leak somewhere (even if it does not let water out when the pump is running). Although this is not likely related to your water loss issue.
