Results 1 to 18 of 18
Thread: new to the forum and SLAM
    May 2015
    wichita falls, tx
    9
    first off, i am so glad i found this site! lots of good info and helpful people!
    i am going to slam my pool to get rid of the swamp but i ran into a bit of confusion regarding cya. my cya was below the measurement with taylor k2006. did it twice and could still see the dot. if i am going to shock my pool using slam method, do i need to raise cya first or just use less bleach(according to cya/chlorine chart? thanks in advance!
    25000g
    fc - 10
    cc - 20
    ph - 7.5
    alk - 80
    cya - 0ish
    38,371
    Re: new to the forum and SLAM
    Welcome to TFP!!!
    First we need to understand your results. Was the CC really that high? How much chlorine did you add and when did you take the above test results?
    With a loss of CYA and the higher than normal CC this could be a case of ammonia.
    I would hold off on adding CYA for now and wait until the FC holds for 30 minutes and the CC level falls.
    Note, use 10ml of water for the FAS-DPD chlorine test so each drop is 0.5ppm
    Also, order refills for the FAS-DPD and the CYA test ASAP as you are going to run out trying to clear out this CC issue.
    May 2015
    wichita falls, tx
    9
    test was done 30 mins ago. fc was 0 last night and I added 3g of liquid pool shock from atwoods (10%)
    38,371
    Please add your pool details to your signature as described HERE as it will help us help you.
    Well, 3 gallons should have raised your FC by 12ppm ... so I do not think it is possible for the FC to be 10ppm and the CC to be 20ppm.
    Can you describe how you did the chlorine test?
    May 2015
    wichita falls, tx
    9
    I'll do another to double check
    when r0870 is mixed color is faint pink. should I add more for darker pink?
    38,371
    How much powder did you add?
    If one heaping scoop, then that should be plenty. If in doubt, add a little extra, but if the color does not get deeper, then you must have low FC level.
    May 2015
    wichita falls, tx
    9
    ugh I suck. I had 10x on the brain when I was doing this earlier, sorry!!
    fc - 1ppm
    cc - 1.5 ppm
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    That is ok. The test can be confusing at first. 10x is for TA
    You want .5x
    Bring your FC back up
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2015
    wichita falls, tx
    9
    so don't worry about cya yet?
    38,371
    OK, please add 10ppm of FC (3 gallons is close enough) with the pump running and then test the FC and CC again after 30 minutes. That will help determine a path forward.
    May 2015
    wichita falls, tx
    9
    will do
    May 2015
    wichita falls, tx
    9
    added 4 gallons 10% before I saw your post to add 3
    fc - 18
    cc - 1.5
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    That is ok.
    Lisa
    38,371
    Well why 4 gallons? You should always be using PoolMath to calculate how much is required to reach your desired target.
    4 gallons should have added 16ppm of FC which is pretty high for a CYA of < 20ppm ... see the FC/CYA Chart.
    At this point it is clear that ammonia is NOT a problem here. So I would suggest you raise the CYA up toward around 30-40ppm and then follow the ShockLevelAndMAINTAIN Process.
    May 2015
    wichita falls, tx
    9
    is there a particular brand/store for stabilizer that you recommend? also could I let fc drop to 10-12 then slam from there or will it not be as effective?
    38,371
    You need to maintain the shock FC level that is appropriate for your CYA level. Right now you should be down around 10ppm. But when you raise the CYA up, you would need to also raise the FC target up.
    Any stabilizer that is close to 100% cyanuric acid is fine. It can usually be found at hardware stores in the pool section or the Walmart HTH stuff seems to dissolve well. Just use PoolMath and put the amount you need into a sock and put it in your skimmer.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Be sure to update your signature so it's easier for everyone to help you out.
    To change your profile and/or signature, select "Settings" (top right under Pool School button). Scroll down (left side) to "My Settings" & select Edit Profile or Edit Signature.
    Use Pool Math to calculate your pool volume and your chemical additions. When in doubt, estimate you pool volume lower at first, especially when adding CYA. It's easy to add CYA, not so easy to get it out.
    Isolated Spa - 345 Gallons
    May 2015
    wichita falls, tx
    9
    gotcha, thanks for all of the help!
