Results 1 to 15 of 15
Thread: Dolphin M% supreme
    Aug 2014
    ny
    9
    Dolphin M% supreme
    Can someone tell me how to set the "arms"..there is absolutely no instructions regarding this...my unit seems to just stay in the deep end constantly. Thanks for any help
    May 2015
    Lexington, KY
    73
    Re: Dolphin M% supreme
    I have a Dolphin M4 Supreme. It sounds like you're having trouble with your Dolphin staying in the deep end? Mine is too. I've Googled the manual and even watched videos and there's nothing about this. Even the pool guy that open and closed my pool said that you just put it in and the Dolphin has it's own diagnostics and knows what to do. Mine will not stay too long in the shallow end and it will not climb up steps (it will climb up walls though). I'm curious as to reading if anyone else has this problem or has found a solution?
    Pool Owner since Sept. 2014, but 2012(ish) in-ground pool. 40'x'20x3'(shallow)-8'(deep). Around 28,000 gallons. Vinyl liner. SWG. Aqua Rite with Hayward T-15 cell. Hayward Super Pump (self priming). Hayward Sand Filter. AquaPro Pro1100e Heat Pump. 2 main drains. 2 skimmers. 2 jets. 1 light. 1 diving board. Dolphin M4. TF-100 Test Kit.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,770
    Mine works great and covers the pool, including a steep slope from the diving well.
    I think I lucked into the right position. On mine the float/control is all the way out on each side and the handle tilts slightly clockwise.
    So when "horizontal" it would be "quarter to three" on a clock and instead mine is more like "ten to four" ish.
    Give that a try and see it it helps.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    It took mine a couple of times in the pool before it started doing everything it should. I have mine set at full forward and full back, floats in and it seems to do well now.
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    Aug 2014
    ny
    9
    Hi can you explain the full forward full backwards setting? sorry so confused but not using this everyday...the robot was a gift for my son
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    There isn't a setting for F/B, it just goes on its own. Perhaps you can expand if I'm missing your point.
    Essential Links:
    Aug 2014
    ny
    9
    trying to find out to set the arms that come out from the handle...and also the position the handle should be set to...ive been told moving these to the proper position is what guides the robot...but no one seems to know what the proper positions are
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Ok, those are floats. They slow him down if they are out. That helps cleaning. The angle will change how he does on the waterline, but that's all I know on the angle. It won't determine where he goes on the floor that I have been able to tell. I too have been frustrated with the lack of instruction on this. Severely lacking indeed. Everything I've learned has been through experimentation.
    Essential Links:
    Aug 2014
    ny
    9
    Thanks Patrick that makes sense to me now...I'll try keeping them both extended and use the tilting suggested by Swampwoman (by the way thats a great name)
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    That's what we've all had to do. Terrible (no) instructions on this and it is puzzling.
    Essential Links:
    May 2015
    Lexington, KY
    73
    I have configured my Dolphin M4 according to Swampwoman. The only difference is that I do not have the "Pro" so I cannot adjust the floats. I put the arms where she suggested. I have noticed that it is spending more time in the shallow end. It still climbs up walls without issue, but the dang thing is just too lazy to go up steps. So what I usually do is align it on my bottom step before it starts so that it can clean that step. I even emailed 2 of Maytronic's email addresses asking for help and ideas---no response. I've watched no less than 6 Youtube videos too.
    BobbyR's Avatar
    Jun 2013
    Toronto, Ont
    142
    Yes, the "instructions" included with the Dolphin are pretty scant and shed no light on the float settings. The higher the angle, the faster the machine will move when cleaning the water line. It's not clear what moving the floats in and out does, if anything. As for staying in the deep end, I have found that the machine works far better in warmer water. In very cold water the Dolphin will not climb the walls and has trouble getting out of the deep end. As the water warms up the rollers soften and get more sticky. This may not be an issue for you in Kentucky but, when I open my pool in late April, the water is very cold, only in the mid to high 40s.
    Lagoon 40x22, Vinyl, 27,000 gal, 1HP WhisperFlo Pump, Pentair 60 gpm Sand filter, Hayward Brominator (used for chlorine pucks only when away), Rheem gas heater, Dolphin M4 Robot
    Waterfall on separate dedicated pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    The floats out slow him down while he's travelling around the pool.
    Essential Links:
    Aug 2014
    ny
    9
    Thanks so much for all the info...would be lost if I didn't find this forum...very frustrating that Maytronics does not offer help on this issue...after using this cleaner for one season, I don't think I would recommend it to other buyers, mostly because of the poor customer support.
    BobbyR's Avatar
    Jun 2013
    Toronto, Ont
    142
    Quote Originally Posted by Patrick_B View Post
    Not so's you'd notice. Seriously, the only effect I see of extending the floats is to interfere with the cleaner hugging the wall as it travels along the floor because the extended floats drag on the wall and cause the cleaner to turn in. This may or may not be what you want. I've noticed as well that reversing the float angle every few cycles reduces cord tangling but this is a minor issue with this cleaner anyway.
    By the way, I love the Dolphin M4. It is by far the best one I've owned and it does a bang up job, lousy instructions notwithstanding.
