Thread: Need help IDing skimmer
    May 2015
    Meriden, CT
    3
    New pool owner here. Just bought this house with a roughly 40-50 year old pool, and I'm still working on learning all there is to know to get it up and running. Previous owners were very unhelpful with info.
    First off, does anyone know what skimmer this is? And if it's missing parts? And if so, where I can find those parts? I'm used to seeing circular skimmers made of plastic so this rectangular aluminum skimmer is throwing me for a loop. It seems to me like there should be a weir flap, and a skimmer basket. The part where the basket would go measures roughly 9" x 3.75" and maybe a couple inches down before it would hit the pipe.
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    If I can't ID the skimmer, I'm guessing I could buy a rectangular basket to roughly fit those dimensions and then maybe cut a hole to let the pipe stick through the bottom of it.
    Also, not entirely sure what the deal is with these valves/piping to the left of the skimmer.
    [IMG][/IMG]
    Eric
    20K gallon, Plaster IG. Hayward SP2607X10 Super Pump 1-HP, Sand Filter
    38,539
    Re: Need help IDing skimmer
    Welcome to TFP!!!
    All I can say is that it looks old
    You are right that you really should try to get a basket in there to catch the debris. You want it to sit above the pipe though so that the debris can not get into the pipe.
    Also a weir will help with the skimming action and retaining the debris in the skimmer when the pump is turned off. Likely you will just have to look into getting one of the universal ones that has spring loaded rubber feet to hold it in place.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    finding a rectangular basket that fits sounds about right
    and if you measure the skimmer door opening, you can probably find a generic weir door on amazon with
    spring loaded fasteners for cheap.
    Dolphin E10 Cleaning Robot.
    May 2015
    Meriden, CT
    3
    Thanks for the responses. After some online research the closest basket I can find to fitting the dimensions was the Aladdin B-122
    http://www.poolpartsonline.com/p-218...jacbasket.aspx
    $50 for a skimmer basket seems crazy to me.. but I guess I don't have a lot of options!
    Eric
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    a bit crazy, but thankfully they still make one that fits!
    38,539
    Wow, that is pricey and other places want $80+
    It is certainly a good idea to have one though so you do not clog up your pump.
