Results 1 to 7 of 7
Thread: CYA/Sun
    Mar 2013
    CT
    351
    CYA/Sun
    Would one normally want a higher CYA reading with more sun light on the pool?
    I'm at about 40 now. I get sun on my pool from sun up to sun down. if I went up to say 50 or 60 - would my daily chlorine loss generally be a little less?
    I've read so many horror stories about CYA on here I'm paranoid to add even a little more!
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: CYA/Sun
    I would only go as high as 50 for now. Yes, you will lose less FC to the sun with a higher CYA.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    38,295
    Re: CYA/Sun
    The higher the CYA, the more protection from the sun. Although the sun in CT is not as intense as what AZ and TX see
    How many ppm of FC are you currently having to add?
    Mar 2013
    CT
    351
    Re: CYA/Sun
    I check every evening. I target 7 ppm and I'm down to about 5 ppm every night. Sometimes a bit less.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: CYA/Sun
    That is a normal loss. I would leave your CYA where is is.
    Lisa
    38,295
    Re: CYA/Sun
    A 2ppm loss each day is on the lower end of normal ... not sure that raising the CYA will result in having to add too much less. But raising it would not hurt anything.
    With your current CYA, you might try targeting 6ppm and you may not have to add quite as much bleach each day.
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    Re: CYA/Sun
    I think you're good were you're at.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
