Results 1 to 9 of 9
Thread: Newbie w/ Cl issues...HELP
    May 2015
    Pittsburgh, PA
    13
    Morning! I'm a new convert to the TFP way of pool mgmt & have been pool schooling myself. This is our 4th season w/ the pool...my issue is that I started the "old" way...ie took water to the pool store for analysis, & used Aquacheck strips to monitor at home. When pool was opened, 2 bottles liquid "shock" we're used, along w/ 1 bottle of algae inhibitor. I added alkalinity & ph up as per the pool store. Also had them check my Phosphorous level as it was sky high last yr; level was 300, so I added corresponding amt of Phosfree (which I now know is unnecessary!). Used 3" trichlor pucks in my chlorinator & turned it to 2...vacuumed...water clear & sparkly...on my test strips I was getting a TC reading, but no FC reading. Added oxysheen to no avail. CYA per the test strip was ~ 90, pool store had it at 100. Did not want to use the smart shock...that's when I came to your site. Have since added 1 gallon 6% diluted bleach while waiting for my TF-100 test kit to arrive. No more chemicals added. Turned off the chlorinator last nite, & here are the readings from my wonderful drop kit: (heat pump is on), water crystal clear and sparkling...
    temp 81
    Cl: 3
    pH: 7.5
    TA: 100
    CH: 175
    FC: 1.5
    CC: 3.0
    TC: 4.5
    CYA: 70
    Oh please help me balance my pool! I am a nurse, & am sick about it! (But am wicked happy about this "chemistry" kit!). Just want my swimmers & equipment to be safe---Thanks!
    New install 10/11, Pgh, PA, IG, vinyl liner, ~21,000 gal, DE Hayward Perflex extended cycle filter w/ Hayward self priming super pump, Hayward titanium heat pro heat pump, Hayward chlorine feeder (eek! it's OFF NOW!); TF-100 test kit
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Newbie w/ Cl issues...HELP
    Your Cya is fine, but maintain a target FC of 8 to be safe. Your cc could be indicating a SLAM SOON.
    Get that FC up asap
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Welcome to TFP methods and your new test kit! As already stated. Get you FC up ASAP.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Jun 2014
    15,121
    I agree. Focus on moderate chlorine additions (bleach only) for now until your kit comes-in and you can confirm all readings accurately. From there, post some new TF-100 numbers and we'll keep you on-track. As you may already know ... don't waste your $$ on fancy pool store chemicals. Start reading-up on the SLAM process and chlorine/CYA chart (links below) for when your kit arrives. You did the right thing by ordering that TF-100. I love mine and it's made my job MUCH easier.
    May 2015
    Pittsburgh, PA
    13
    Quote Originally Posted by Texas Splash View Post
    I was concerned about the CYA level & wondered if it was time to SLAM, or how much bleach to add if just an addition; shall I input my #'s into the pool calculator to determine how much bleach? Shall I put my FC goal as an 8?
    thank you so much for your prompt replies!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Yes use the Pool Math calculator to determine amounts to add. Once you have your test kit you will be able to get a good reading on everything including CYA and we can help you address it then.
    Lisa
    May 2015
    South Park, PA
    39
    I didn't order the SpeedStir with the original purchase of my TF-100, but after hearing about it from other users I ordered one. The SpeedStir makes testing with the TF-100 a lot easier (faster). Might want to think about it if you are heading into the SLAM process. It isn't necessary, but nice to have.
    30,000 gal inground (20 ft. x 40 ft. w/ deep end), vinyl liner, Pentair Clear & Clear 420 cartridge filter, single speed 1.5 HP Pentair Whisperflow pump, heat pump, SunTouch controller
    May 2015
    Pittsburgh, PA
    13
    Thanks Scott, I will certainly consider the speedstir!
    Lisa, the results I posted are from my TF-100 test kit ;0). I'm ready for your suggestions! Sorry if I was unclear!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Ah ok. It said waiting for test kit to arrive in your post, so I did not think it was here. Sorry about that.
    Ok, so you don't have a SWG correct? If not then yes do partial drain and refill processs to lower CYA to 30-50 range.
    Your FC is to low. Use the pool math calculator to determine how much to add to bring FC to recommended level. Target 8 minimum 5 for your current CYA of 70
    Lisa
