Results 1 to 7 of 7
Thread: Taylor Testing Question
    Mar 2013
    CT
    348
    I have a Taylor K-2006 Test kit That I have been using the past two seasons.
    The only tests I have used my kit for are FC, CC, pH and CYA.
    My most recent numbers are:
    FC: 6
    CC: 0
    pH: 7.3
    CYA: 40
    Water is like glass. Absolutely crystal clear.
    My pH never fluctuates (I test the pH about once a week) and the only thing I ever do is add bleach on a daily basis after testing. I test chlorine daily. I use 6.0% Clorox bleach for chlorine.
    Is there really any need to use any of the other tests in the kit for any reason?
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Taylor Testing Question
    It is recommended you run all test once a week. Your TA can be an important one.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It's not a bad thing to have a base line on other things like TA and CH. Sounds like things are stable, but I would get those numbers down for reference. Just keep the pH and Free Chlorine in line if those others are as ok as it sounds.
    Essential Links:
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    I run TA once a week, but I don't run CH. With a vinyl pool you won't need to worry much about that either.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    38,242
    I agree with Lisa. I would check the TA every few weeks, although given that your pH is stable, there is not really a need to change it.
    I would also check the CH just so you know where you are at. Even in a vinyl pool you could develop problems if it was too high. Although given your shorter season and likely partial draining for winter, this is not likely a problem.
    Congratulations on having a truly trouble free pool
    Mar 2013
    CT
    348
    Thanks! I couldn't have done it without this site!!!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Looks beautiful!
    Lisa
