Hello,
So opened a green pool for my second year as owner of one.
1st test of the season
Ph 8.2
FC .5
Cc 2.5
Calcium Hardness test
Color is more pink then red
200
TA 50
CYA 0
I started to address TA and Ph and CYA as I learned before starting SLAM. Below is the results between yesterday and this morning. Unfortanuly my levels of TA and CYA have gone up and my CH has gone done?
I have been running filter while around a recycle at night only because it needs to by back washed so far once a day.
After 1 hour 3:38 pm
FC 7.5
Cc 1.5
Cya 30
TA 60
4:36pm sun off pool for most part
Back washed filter and set to recirculate.
FC 13
6:20m
FC 10
8:30 pm
FC 10.5
Cc 1
Next morning 2nd day
Ph 7.2
FC 9.5
CC 1.5
CH 150. (Went Down)
TA 100. (Went up)
CYA 40.
10:30 am
FC 14.5
Cc .5
I guess some more CYa had dissolved and raised up but with all the backwashing and adding water that will go back down. Should I address the CH now or wait till Slam done? Als as I check chlorine should I let sample sit a little while? Sometimes it started to turn back color after 30 sec or so? Thanks
Ph 8.2
FC .5
Cc 2.5
200
TA 50
CYA 0
FC 7.5
Cc 1.5
Cya 30
TA 60
FC 13
6:20m
FC 10
8:30 pm
FC 10.5
Cc 1
Ph 7.2
FC 9.5
CC 1.5
CH 150. (Went Down)
TA 100. (Went up)
CYA 40.
10:30 am
FC 14.5
Cc .5
