Results 1 to 19 of 19
Thread: What I believe to be scaling, requesting assistance with resolution
    May 2013
    Monmouth County New Jersey
    19
    Hi All,
    We did a pool renovation last summer (August 2014), I closed the Pool on 9/20/14 with a PH of 7.2. The pool was opened yesterday and after opening yesterday and running the pump for 5 hours:
    I am currently using CL tabs and once this is resolved I will add the salt and convert over to the SWG.
    On the walls of the pool I have deposits with a texture similar to sand, I was able to brush these off and vacuum them out, see pic
    If this is scaling did the minerals come out of the finish or the water?
    Will keeping the PH at 7.5 during the season help dissolve whatever scaling might be there?
    The deposits in the SPA are firmly attached and will not brush off, could the issue in the SPA be more serious due to the lower volume of water or difference in temperature over the winter?
    What is the best way to remedy the SPA; I have read that an Acid wash or the use of a Pumice stone could make the surface smoother. I am leaning towards a Pumice stone, the spa is small and shouldn't take too long. Is the Stanley Pool Tec stone recommended?
    Amazon.com : Stanley 36897 Pumice Stone - Large : Swimming Pool Cleaning Tools : Patio, Lawn Garden
    Jim
    35,000 Gallon Gunite (circa 1990), Diamond Brite(renovation 2014), Built in SPA, 48 Sqft DE filter, 2HP Pentair single Speed, 300 BTU Heater, Solid Anchor cover, Aquabot Turbo T4RC, CircuPool Si 60+ SWG, TF-100 Test Kit
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: What I believe to be scaling, requesting assistance with resolution
    Someone else had this happen, but I cannot remember what they determined it was. Hopefully someone will remember.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    I believe it was determined to be pollen or tree debris in both of the two cases I remember. But, this looks a little more crystallized and less organic.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    There were 2 threads that had this crystallization.
    Here is one of them.
    Sediment/Crystals on pool bottom
    Lisa
    30,432
    With a pH of 9.0+ (how did you measure that?) and a CH of 350 ppm, that would certainly indicate calcium scale that came out of the water.....it did not leech out of the finish.
    7.5 pH will probably prevent further scaling but won't get rid of what you have.
    I have no experience on a particular brand but I would suggest a pumice stone on the spa as well.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to TFP Jim,
    Looks like the pH 9 was a pool shop reading? That would be considered extremely high for a pool if correct, but would certainly help contribute to minerals precipitating like that, even if it were a little lower.
    What else have you used in the past? Specifically for pH control? I do suggest getting a proper kit to measure these things yourself and eliminate any doubt about your actual levels. Often, these store readings are wildly off from reality, but something is obviously going on here.
    Essential Links:
    May 2013
    19
    Quote Originally Posted by Patrick_B View Post
    Welcome to TFP Jim,
    Hi All and thanks for the replies. Sorry for the 9+ reading it was just a notation to myself to indicate what appeared to be an off the scale reading (above 8.2). I use the TF-100 test kit for my testing and the pool calculator to adjust chemistry. The 150oz of MA did bring the PH down to 7.5, I guess I could try to reverse calculate what effect 150oz of MA would have on ~35K gallons.
    The history here is that it was renovated last August and the pool did have a very healthy appetite for MA. I was checking every 2 days and adjusting as necessary. I was using the TF-100 kit and the Pool Calculator and the two worked wonderfully.
    I was a bit worried that I would not be able to control PH after closing. The Pool Contractor suggested I get the PH down to 7.2 and a TA of 120 prior to close which I did. When we opened it was as I described above. The surface of the finish looked to have crystals/sand on it which brushed off and vacuumed out. The surface feels a bit rougher than last season. I don't mind using pumice on the seating surfaces, but how best to handle the rest of the pool, is an acid wash necessary?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Did you see my link in post 4?
    Lisa
    May 2013
    19
    Quote Originally Posted by Azgirl71 View Post
    Yes sorry I forgot to mention that. I took a look at that link and my deposits not as crystalline as those in that thread and definitely not as severe as those calcium sulfate deposits mentioned in the article.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Ok. Glad you saw it.
    Lisa
    umpalumpajay's Avatar
    Dec 2014
    West Hills, CA
    157
    aaaaah, the mystery crystals!
    12000g pool + 1000g spa. Jandy 2.0hp epump + separate Jandy pump for Sheer Descent. Jandy CV Cartridge Filter. Jandy Lxi gas heater. Tropical Breeze PebbleTec. Aqualink. Aquapure SWG. Nature 2. The Pool Cleaner 2x. Taylor K-2005.
    May 2013
    19
    Update:
    Based upon browsing this forum:
    I tried dropping the sediment into MA and it fizzes, is this the acid test for calcium-something?
    I believe that this is a minor scaling issue so I dropped the PH to 7.2 yesterday and it appears that vigorus brushing helps to remove what is left of the stuff.
    I ordered some of the Stanley Pumice and will use it to smooth the seating areas. From day 1 the diamond brite was rougher than the plain marble dust plaster that was the original finish.
    Mar 2007
    San Rafael, CA USA
    12,082
    Yes, you have confirmed that this is likely to be calcium carbonate scale. The acid is reacting with the carbonate to produce carbon dioxide gas.
    The scaling was likely brought on by the very high pH, along with CH and TA that may have been "normal" (but not low).
    May 2013
    19
    Thanks chem geek. I am going to be adjusting chemistry (TA) for a SWG, when I close this autumn (Oct - May). Is there anything you can recommend to avoid this happening next year? Lower CH? Testing and adjusting Chemistry while pool is closed?
    Mar 2007
    San Rafael, CA USA
    12,082
    Because the pH ended up higher than would occur from carbon dioxide outgassing at your TA level (i.e. it was well above 8.4 in pH), the pH rise is most likely from the plaster since you had a renovation. The continued curing of plaster raises pH significantly. There is nothing you can do to stop it except to have done a bicarbonate startup when the plaster was done since that creates a more solid stable plaster surface with more complete and rapid conversion of calcium hydroxide (that would otherwise raise pH) into solid calcium carbonate as part of the plaster itself.
    You could test and add acid when the pool is closed, but would have to do something to mix the water to prevent acid pooling. You could, as you suggest, lower your CH level, but then that risks some dissolving of the plaster over the winter though at colder temperatures that is much slower to occur and you'd have to add back the CH upon opening so that doesn't sound like a very good plan. You probably won't have this happen next year, or at least not as much, because the plaster should not be causing as much of a rise in pH by then.
    May 2013
    19
    Thanks again, That makes sense the acid demand is lower than it was last year.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    I put your numbers into pool math and the amount of acid addition didn't seem to correspond to the results you got. Would have expected an effect on TA but there wasn't any in your test results. I assumed 31.45% muriatic but you may have used the 14.5% stuff. The starting pH wasn't a firm number either so that could explain it. Your pool volume of 35000 seems pretty high for what looks to me to be a mid 20K pool. Can't say I can judge with certainty from the photo, but you may want to verify your volume calculations so you can hit your targets on the money in the future.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    May 2013
    19
    Quote Originally Posted by gtemkin View Post
    Thanks, the first PH number was a guess since it was off the charts. The pool is 35K gallons, the length is over 50 feet, I took a water meter reading before and after filling it; the deep end is real deep at 9 feet.
    For the first acid adjustment I will come clean and admit that I used 1 gallon of the 31.45% stuff and about 1/3 gallon of the mystery "safer no smell unknown percentage" MA that I had left over. I won't be buying that in the future. The home depot used to sell both types but now only carries the Safer stuff, I now buy the real MA at the masonry supply.
    Mar 2007
    San Rafael, CA USA
    12,082
    When plaster is curing and releasing calcium hydroxide into a pool, the pH, CH and TA all go up. When one adds acid, the pH and TA are brought back down. So there is no net drop in TA if the acid addition is required due to plaster releasing calcium hydroxide.
    The net drop in TA from acid addition only occurs when the reason for having to add acid (i.e. the reason the pH is rising) is from carbon dioxide outgassing.
